forum crashing
- Bing
Re: forum crashing
I have had a couple of time on my iPad where the forum has frozen, then when I try to re-load it use hangs. Using safari on the latest version of IOS
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
- markeg
forum crashing
I have memory leak issues with IE9 and latest Firefox running on a Win 7 platform, but all runs fine with Chrome. Looked at plugins/add-ins but no sign of anything there. Also runs fine with chrome and Win8 on my testbed laptop. Moral? Use chrome
previous: Alpina Roadster S, #108: gone
current: MB C-class
"veni, vidi, velcro - I came, I saw, I stuck around..."
current: MB C-class
- WLH
Re: forum crashing
No problem here...
Mac OS X 10.7; rv:12.0 using SeaMonkey/2.9.1
- ksher
Re: forum crashing
I have the same problem recently. My PC has Windows 7 and IE9.
Current BMW: 640d Gran Coupe M Sport (F06), 118d SE (F20).
Previous BMW: Z4 sDrive23i M Sport (E89), 318i Sport (F30), 120d SE (F20), Z4 2.5i Sport Roadster (E85), 523i Sport (E60), 323Ci (E46), 523i SE (E39), 318i (E36).
- andysat
Re: forum crashing
I wonder if woots' thread has something to do with it?
Gone but not forgotten.
New ride silver e93.
- cj_eds
Re: forum crashing
No problems with Vista/Chrome here
- Stuart Truman
Re: forum crashing
Win7 64bit with Firefox running fine. Tapatalk however is as reliable as ever...
Add yourself to the Z4 Map HERE! Instructions HERE!
Z4M Roadster, Imola Red, with Stubby and Intravee II. Low Miles per Gallon, High Smiles per Gallon
Previously Alpina Roadster S #69 Alpina Blue
- markeg
Re: forum crashing
I have Win7 64 bit (sp1 applied) with Firefox and find it just keeps creeping up on the memory. Yesterday after an hours and a half use, it was running at just under 2 Mb! Need to look into it a bit more as its only on this forum it happens...... otherwise I'll just use chromeStuart Truman wrote:Win7 64bit with Firefox running fine. Tapatalk however is as reliable as ever...
current: MB C-class
current: MB C-class
- Stuart Truman
Re: forum crashing
Firefox definitely has a memory leak, but it's not the forum crashing. In fact I took a look at task managermarkeg wrote:I have Win7 64 bit (sp1 applied) with Firefox and find it just keeps creeping up on the memory. Yesterday after an hours and a half use, it was running at just under 2 Mb! Need to look into it a bit more as its only on this forum it happens...... otherwise I'll just use chromeStuart Truman wrote:Win7 64bit with Firefox running fine. Tapatalk however is as reliable as ever...
Time to try Chrome...
- markeg
Re: forum crashing
My suspicion is that its Firefox memory leak and Adobe flash that are combining to cause Firefox to 'hang'...Stuart Truman wrote:Firefox definitely has a memory leak, but it's not the forum crashing.markeg wrote:I have Win7 64 bit (sp1 applied) with Firefox and find it just keeps creeping up on the memory. Yesterday after an hours and a half use, it was running at just under 2 Mb! Need to look into it a bit more as its only on this forum it happens...... otherwise I'll just use chromeStuart Truman wrote:Win7 64bit with Firefox running fine. Tapatalk however is as reliable as ever...
current: MB C-class
current: MB C-class
- Stuart Truman
Re: forum crashing
Edited my last. Bloody Hell. It might be heresy, but IE9 is getting good reviews...
- markeg
Re: forum crashing
shhhhh........... heard the same, but am also finding out that IE9 hangs after a while. Chrome is the only one of the three that is working cleanly for me
current: MB C-class
current: MB C-class
- markeg
Re: forum crashing
So, I believe I have tracked it down. It also crashes in Chrome, but only the plugin so the browser stays active. In IE and Firefox it causes either the browsers to increase memory footprint until they either crash or hang, a dependent process to do the same(like plugin-container), or both . Culprit is good old Adobe Flash, which I believe is being used to run the ads in the top left of the forum window...
Have checked and am running the latest plugin. Also checked Adobe and there are a number of bug reports on browser crashes (I found around 1800 on a simple search) - see here.
Until there is an updated plugin, think the answer is use chrome, or keep closing/opening your browser of choice.
current: MB C-class
current: MB C-class
- Stuart Truman
forum crashing
I noticed Chrome runs multiple instances in task manager. if you add up all the instances it wasn't far off Firefox.
I'm running Adblock pro, which ought to eliminate Flash as a cause as you suggest, but I still get memory leaks
Tapatalking...
Tapatalking...
Re: forum crashing
its started hapening again on 4 different computers. sometimes i cant even get off the front index page. is there a new update out i should be installing as its always that advert at the top that seems to be blank waiting to load.markeg wrote:So, I believe I have tracked it down. It also crashes in Chrome, but only the plugin so the browser stays active. In IE and Firefox it causes either the browsers to increase memory footprint until they either crash or hang, a dependent process to do the same(like plugin-container), or both . Culprit is good old Adobe Flash, which I believe is being used to run the ads in the top left of the forum window...
Proud Whip owner
