Seriously stressed :(
smlbjanusz01
Post by smlbjanusz01 » Fri Apr 07, 2017 10:32 pm
Hiiiii everyone, I'm hoping someone will be able to point me in the right direction :thumbsup: so I was getting 2 incorrect gear ratio codes on my 2005 3.0 z4 so I had the box serviced, the fluid was very metallic but it all been changed now. The car went back into limp mode after about 4 miles but is now giving me an incorrect gear ratio code for gear for which it has never done before and the problem seems to be in gear 2/3. Short of changing the whole box is there anything else that's worth a try? I really don't have a clue where to start so any help would be much appreciated
firebobby
Post by firebobby » Fri Apr 07, 2017 10:56 pm
smlbjanusz01 wrote: Fri Apr 07, 2017 10:32 pm Hiiiii everyone, I'm hoping someone will be able to point me in the right direction :thumbsup: so I was getting 2 incorrect gear ratio codes on my 2005 3.0 z4 so I had the box serviced, the fluid was very metallic but it all been changed now. The car went back into limp mode after about 4 miles but is now giving me an incorrect gear ratio code for gear for which it has never done before and the problem seems to be in gear 2/3. Short of changing the whole box is there anything else that's worth a try? I really don't have a clue where to start so any help would be much appreciated
Manual or auto box ?
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
smlbjanusz01
Post by smlbjanusz01 » Fri Apr 07, 2017 11:08 pm
Hi it's an automatic box
firebobby
Post by firebobby » Fri Apr 07, 2017 11:20 pm
Did they use the correct fluid for the box, did they change the filter in the box, who dd the work. Did the box just start playing up or has it been doing it for a while? these are pretty bullet proof boxes.
Toyota MR2 NA 1995
Mini 1000 1981
smlbjanusz01
Post by smlbjanusz01 » Sat Apr 08, 2017 12:16 am
Yep, correct fluid was used, I had the filter and gasket changed too. I did think these were pretty strong boxes as I can't seem to find much on them. I used a local mechanic that was recommended to me, he seems to think it's the solenoids. I'm just baffled by the different code. I'm happy to change the box but I'm worried it could be something else that maybe causing the code. I've changed the battery incase it was a voltage problem. I'm so close to giving up but I've just got the car looking how I want :(
smlbjanusz01
Post by smlbjanusz01 » Sat Apr 08, 2017 12:17 am
Oh sorry, started playing up 2 weeks ago, kept going into limp mode when pulling off or going up hill
csquire4
Post by csquire4 » Sat Apr 08, 2017 10:31 pm
Try a BMW specialist (or dealer) before you consider changing the box. It could be something as simple as a gearbox software update. I had an 2001 E39 with auto, I took it to PMW in Chelmsford for a gearbox oil change, they told me my gearbox was 2 software updates behind!!. It was nicer afterwards.
Exactly what oil was used for your oil change ?
2004 3.0i, manual, toledo blue
