I've had the car for about 4 years and for the last 18 months the engine starts readily, runs for about 20-30 seconds and cuts out.
It starts again ok and run again for 20-30 seconds and cuts again. If you keep the revs at about 1500 it will just blip and carry on running.
Its a cut in the ignition because if I push the button for sport mode it will cancel that. Once the engine is up to temperature it runs fine with no problems. I've taken the car to a BMW main dealer and they put on there diagnostic kit, and found no fault. It must be temperature
related because when it gets up to running temp. its fine. Help.
2004 z4 3.0i engine cuts out when cold
