Cool, cant wait to see this done. where are you based and what would you charge?
The indicator surrounds can be removed, pop the bonnet and i believe they twist from the inside to get them out/
Playing about with a few brands at the min I will get a few metres of avery and see how it wrapsRuss59 wrote:What vinyl are you using?
I sometimes help my mate in his business and the Avery is well worth the extra ££££'s
Lotus wrote:Does anyone know how the glass in the wing mirror is removed ?
Perfect thankyousynthedup wrote:Lotus wrote:Does anyone know how the glass in the wing mirror is removed ?
Under the mirror is a small torx bit to remove the black plastic cover, remove that, then there is a large black circular clip. using a screw driver you can twist it about 10mm and the glass will fall out.
. . . sometimes the glass falls out all by itselfsynthedup wrote:Lotus wrote:Does anyone know how the glass in the wing mirror is removed ?
Marlon wrote:. . . sometimes the glass falls out all by itselfsynthedup wrote:Lotus wrote:Does anyone know how the glass in the wing mirror is removed ?
Lotus wrote:Perfect thankyousynthedup wrote:Lotus wrote:Does anyone know how the glass in the wing mirror is removed ?
The Avery goes down a treat compared to some of the cheaper one's which can be a nightmare to work with.Lotus wrote:Playing about with a few brands at the min I will get a few metres of avery and see how it wrapsRuss59 wrote:What vinyl are you using?
Just seen this if you go Avon or 3m around the 5 year mark cheaper vinyls about 3Sky-drive wrote:not a big fan of the Maldives blue on mine so have been considering getting my Zed done in Estoril blue.
Undecided on whether to have a full respray or a wrap ... any ideas on the longevity of a vinyl wrap?
