Well, I'm very embarassed to admit that it had been a year & 9 months (about 3,000 miles) that I had been driving my Z4M with screwed up wheel alignment. During this time I tried 5 sets of aftermarket suspension - TCK coilovers version 1 (with the strut clunks), H&R springs, Eibach springs, KW coilovers before finally going back to TCK coilovers - this time version 2 without the strut clunks. I finally got all the big & small issues worked out. This morning I had my Z4M corner balanced & wheels aligned at Cantrell Motorsports in Kirkland, WA, exit 20 I-405 for those who are local.
First of all, I'd have to say the owner Colin Cantrell is absolutely easy and awesome to work with. Cantrell is a very race oriented shop specializing in Porsches. They own/tune/race 5~6 Porsche race cars that they have in the shop. Also, when I was there this morning there were:
- 997 GT3
- 997 Turbo
- 996 GT3
- 996 Turbo-S [Edit: this was owned by Cantrell]
- Lotus Exige S
- Lotus Elise
All customers' cars. If those owners trust the shop enough, I think my lowly Z4M would be okay as well.
I took pictures of the shop/cars with my cell phone and will post them up later.
The whole job took about 1.5 hours (for both corner balancing & wheel alignment). I went in with 5/8 tank of gas. I usually fill up when there's 1/4 (or 2/8) of a tank left. So I figured 5/8 is right down the middle between 2/8 and 8/8 (full tank). I weigh about 160lbs, and Colin put 160lbs of weight on the driver seat. I left the tool set, the M-mobility kit (air compressor & tire sealer), and another 3lbs~5lbs of crap in the trunk since I always drive around with them anyway.
I was surprised to learn that my ride height was set up nearly perfectly even before doing any adjustment. Only the driver rear needed to be raised about 1/8". The car's now absolutely perfect 50.0% front & 50.0% rear with the driver in the car. Even without corner balancing, my ride height set-up was probably okay, but it was nice to get it done anyway for the peace of mind.
Here's the alignment specs that Colin recommended and that I went with:
Front camber: -1.5
Front caster: 8.0
Front toe: 0.05
Rear camber: -1.8
Rear toe: 0.16
EDIT: Added 09.19.2008
Here's an update on the car weight.
Initially when I posted the thread I had written (or typed) the car's total weight, which I edited out because I didn't think the weight numbers were quite accurate. I had the stock exhaust put back onto the car today so I had Cantrell re-weigh the car again. I went in with 5/8 tank of gas like last time. Turns out that since they did corner balancing & alignment at the same time the first time, the car was weighed with the alginment bracket things attached to the wheels.
Here's basically what I initially wrote:
My Z4M weighs in at 3262lbs without the driver & with the following mods:
- Hardtop (57lbs according to Ron Stygar)
- TCK Koni shocks and springs (about 10lbs lighter than stock struts/shocks & springs)
- 19" BBS RGR's and 235/25/19 & 265/30/19 Goodyear Eagle F1 GS-D3's (about 20lbs lighter than stock wheels)
- heated seats / manual seats (I've read that for power seats, the motor adds 20lbs in each seat)
- 2lbs of closed cell foam from my sound proofing project
- OEM strut brace (about 4lbs)
- 5/8 tank of gas
So without the hardtop and without the 10lbs of crap in my trunk, the car would weigh in just a tad under 3200lbs.
The total weight I got today was 3237lbs. Every other condition stayed the same. So without the hardtop & 10bs of crap in my trunk, the weight would be 3170lbs. That's compared to the 3197lbs that BMW quoted for the Z4M-roadster. I'm not 100% sure what's BMW's process to measure curb weight and how much gas they put in their Z4M; I do know that they test the cars basically bare-bone without any option. I think my Z4M's weight now is certainly much more accurate and reflects the weight I've lost with the wheels & suspensions.
- 997 GT3
- 997 Turbo
- 996 GT3
- Lotus Exige S
- Lotus Elise
I took pictures of the shop/cars with my cell phone and will post them up later.The whole job took about 1.5 hours (for both corner balancing & wheel alignment). I went in with 5/8 tank of gas. I usually fill up when there's 1/4 (or 2/8) of a tank left. So I figured 5/8 is right down the middle between 2/8 and 8/8 (full tank). I weigh about 160lbs, and Colin put 160lbs of weight on the driver seat. I left the tool set, the M-mobility kit (air compressor & tire sealer), and another 3lbs~5lbs of crap in the trunk since I always drive around with them anyway.
Front camber: -1.5
Front caster: 8.0
Front toe: 0.05
Rear camber: -1.8
Rear toe: 0.16
- 5/8 tank of gas
