Not a chance Kap, mechanicals yes no problem, bodywork is for someone else..Kap'nZ4 wrote:3000 grit sand paper, wet, do it till you see the deep marks gone, after you wipe off with water. The water shows you where you need to sand as its like wet paint. After it looks clear with a wipe, dry, polish a couple of times. Dont let the polish dry, wax and seal. Will look like brand new.
This scuff advice please
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
Sounds good, I don't mind paying for a perfect job. Thanks for that.ekimj10 wrote:I would factor in a cost of between £100 and £200 for someone to make a perfect job either at home or in a workshop.
The results I've had from a local company coming to the house and doing it on the drive have been remarkable, damage incurred on the garage brickwork and a lot worse than yours.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- Lynchy
Bexleyheath, Kentjohn-e89 wrote:Derbyshire Lynchy, shame, I would have given you a shout if I was nearer. Having said that, the car is on Baker St London, if I bought it how far are you away from central London?Lynchy wrote:Whereabouts are you John ?
- pvr
Can you do "old" paint Lynchy? It has always irritated me that on my 1993 Golf, a 2 inch wheel arch scratch was touched up 22 years ago with a touch up stick that is not perfect.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- Lynchy
Yes mate I can
- Lynchy
I could have a look when I come over for breakfast
- pvr
You can indeed. Putting the car into an MOT and service this week, not been out in it for a year
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Didn't know you were a paint wizard Lynchy, no wonder your car looks stunningLynchy wrote:Yes mate I can
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Lynchy
Thanks matefirebobby wrote:Didn't know you were a paint wizard Lynchy, no wonder your car looks stunningLynchy wrote:Yes mate I can
Just a courtesy post Lynchy, I did'nt buy that car in the end, otherwise I would have given you a shout, but thanks for the post.Lynchy wrote:Whereabouts are you John ?
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
John..
If you bring it over i will try and correct it...
You have nowt to lose if you fancy a ride out ? Probably 30 mins away..
Hey cheers for the offer Gaz but I did'nt buy the car after all, guy was 3.5k over priced, I don't mind a bit but he was way over, I would have lost a packet.Z4M-2006 wrote:John..
Thanks muchly though mate. Wheels go to prestige in Furness vale on Monday.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
Sweet...
Its all good.
Im not far away if you want it sorting....
Its all good.
- pvr
He does not have the car with the scuff so doubt it
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Oh right...
Read it wrong,thought that was on Johns car...
