Help coding / programing using WinKFP
- kis
Hi all,
It's been a while that I've had a busted Airbag Control Module (or Safety Control Module)... If you want to know the background I posted on two different threads as things progressed. One my own, one from someone else with similar issues. See here and here.
To summarise, me and mac27040 (again, big thank you) have problem solved the issue being the airbag ECU. I purchased a second hand module from ClassicCarSpares2015 (well known breaker) after many months of searching. The unit was not in a crashed car. This was fitted and works initially after all error codes are deleted, however when the ignition is turned off (and then back on) the airbag light reappears. This is due to a car / module chassis or vin number conflict. The unit itself works fine.
This brings me to my question, has anyone successfully coded their chassis number onto a second hand module? If so, how and what platform was used?
Thanks!
____________________________________
10/04/2017
Looking for someone (with recommendation) with WinKFP program in the Surrey / West Sussex / London area.
Thank you!
Thanks!
10/04/2017
Thank you!
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Help coding used modules
This sounds like a job for WinKFP or ISTA-P. ISTA should be a bit easier to use but I've not had experience using either to recode.
If you still have old module you could simply swap eprom, no programing required.
- kis
Thanks Scooba_Steve. I'll look into those.
Marius, I have the old module but it's not working correctly? By eprom? How can you swap the programming? What platform?
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- paddy wright
Try these guys- reprogrammed the module on my wife beetle convertible with no issues
http://crashdata.co.uk
Don't matter ,you only replacing memory that holds car details . Much simpler solution considering you have no idea how to program it .kis wrote:Thanks Scooba_Steve. I'll look into those.
- kis
You talking about physically replacing the section of the module which holds that data? i.e. swapping memory from one to the other. Would it be a simple plug and play? I don't think BMW would have made it that easy!Marius wrote: Don't matter ,you only replacing memory that holds car details . Much simpler solution considering you have no idea how to program it
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- mac27040
looking into it WinKFP should do it then DIS to activate the system
3.0i SMG Supercharged,19" CSL, AvinUSA android 10.25” screen,DSP,M6 gearknob,Coilovers,Aero F-bumper,M r-bumper,Aero skirts,Facelift front & rear lights,M sports seats,Carbon Steering wheel,Intravee,Rervese cam,Hydrographics
BMW don't make electriconics and yes it's simply swap. Soldering required but I guess that was obvious.kis wrote:You talking about physically replacing the section of the module which holds that data? i.e. swapping memory from one to the other. Would it be a simple plug and play? I don't think BMW would have made it that easy!Marius wrote: Don't matter ,you only replacing memory that holds car details . Much simpler solution considering you have no idea how to program it
- kis
Right so fairly certain that we need WinKFP. Anyone know anyone in Surrey / West Sussex (or even around London) that knows their way round the program?
(original post updated to reflect this post).
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- kis
So I'm reviving a pretty old thread, but I guess I'm allowed as I'm the OP!
I'm still in this position so if anyone in the London area (M25 sort of radius) has any experience or knowledge then it would be a great help. Other than Carly I've no experience of any other software, so don't want to do anything stupid (which potentially I may end up doing tomorrow because I have access to the machine/software from Neil). HELP please
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
