Oh well, you can't have everything - cherry would look nicer!
- Mr Tidy
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
One day you will all see how good wood is
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
I fitted my hard top
And fitted my MFSW, just need to get the retro fit cable, are they still available from BMW ??
And then fitted my spacers (Thanks Dan)And fitted my MFSW, just need to get the retro fit cable, are they still available from BMW ??
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Ducklakeview
Did the MFSW myself earlier, made my own loom and connected into the car in the pedal area rather than at the LCM, as it's tight behind the dash for working space.
Mike
So did you pick up the same 2 wires, just lower down the loom then Mike. Am I right in thinking one comes from the radio and the other from the lighting circuit. Did you just use normal vehicle wires ?? How did you connect into the wheel plug.Ducklakeview wrote: ↑Sun Oct 22, 2017 3:58 pmDid the MFSW myself earlier, made my own loom and connected into the car in the pedal area rather than at the LCM, as it's tight behind the dash for working space.
Mike
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Ducklakeview
firebobby wrote: ↑Sun Oct 22, 2017 4:12 pmSo did you pick up the same 2 wires, just lower down the loom then Mike. Am I right in thinking one comes from the radio and the other from the lighting circuit. Did you just use normal vehicle wires ?? How did you connect into the wheel plug.Ducklakeview wrote: ↑Sun Oct 22, 2017 3:58 pmDid the MFSW myself earlier, made my own loom and connected into the car in the pedal area rather than at the LCM, as it's tight behind the dash for working space.
Mike
Yes m8, traced them down. I used a bit of twin core bell wire type cable I had left over from worrying the electromagnetic locks on the garage door, and pulled a couple of terminals from the donor car as it no longer needs them, and soldered the new cable to them.
Mike
Popped the CDV off the M this afternoon. Very pleased, has made a quite noticeable difference. I know some M owners don’t find any difference but I have, well worth doing.
Here’s the little fella and a pinky for size comparison if anyone wonders.
- 5B58D8E5-D5B1-4A60-97F0-22CBF7DB3612.jpeg (357.5 KiB) Viewed 941 times
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- Ducklakeview
As well as doing the mfsw wiring, I decided to split my clocks as the dust inside them was annoying me.. Look much better now. Also adjusted the ring on the lower steering motor, hoping to smooth it out a bit. Will find out on my way to work if it's been effective.
Mike
Mike
- Marlon
Thats one hell of a productive day - well done Fred
Gone: 3.0si 2008 E85
911 997 Carrera S
Onlinebuzyg
Dragged the Zed kicking and screaming out of the garage, in the rain and took it for a drive out on the moors. Got it filthy dirty. Ragged it's round behind on the way home, as the roads were bone dry by then. Then washed and hoovered and tucked away till the next time.
I love my Zed.
I love my Zed.
- philbo909
will you get the hardtop resprayed, or stick with the contrasting colour?
Sapphire black z4 coupe 135,000miles young
- Mr Tidy
Had an early drive over to Ockham and met RickRob for a coffee - nobody else turned up, even though the weather was fine!
Then when I got home I replaced my stubby with a whippy in the hope I may get more than crackles on the radio (I meant to do it before I went out, but I'm only half awake at 08.00 on a Sunday).
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Thanks Collin, although breeze Brian was smashing the UK , it didn't put me off and I dug deep mate
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
I will keep it black, same colour as the soft top
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Proper aerial, good man Tidy, just need to get you some wood mateMr Tidy wrote: ↑Sun Oct 22, 2017 8:26 pm Had an early drive over to Ockham and met RickRob for a coffee - nobody else turned up, even though the weather was fine!
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
