Roof - what should happen?
So yesterday I got my roof motor out, now when I connect it to a battery it sounds very nicely! DIY removal and refurb was absolutely worth it. I encourage anyone thinking about it to do it!!
However after connecting it back up in the boot, nothing happens at all. No noise, the windows don't even drop in preparation for the roof to open!
So there must be an electrical problem - if the windows aren't even dropping when I press the roof open button, is this likely to be because the circuit is "incomplete", I.e there is a break somewhere in the boot cables? Or am i facing a bigger electrical problem?
- Rusky
Havent got your parcel shelf up have you?
3.0l Silver SMG, whippy and ginge fringe/ Sound gen mod/ Media bridge fitted (bluetooth and audio streaming) / Clear third break light/ Hard Top/ Eibachs springs and DLV back box/ Roof motor in the boot/ plus lots more.
- markplant
Is the shelf in the boot in the lowered position, or has the tab off said mircoswitch broken off
I don't even have the parcel shelf in the car right now, it's still off from when I needed access to my motor for removal
What's this micro switch?
- markplant
The shelf when in the lower position hits the mircoswitch an allows the roof to work , sounds likely this is the issue
- markplant
The micro switch is in the middle of the rear bulkhead towards the top, if yes press an hold it in an get some one to press roof button or press an hold unlock on your keys it should work
- Rusky
if the shelf isnt fitted then i think the car will think its up and therefore not let you operate the roof. Step in any time Mike (DLV)
Bingo this is the problem! It's running. Now the new problem, how do I fit the parcel shelf without damaging the roof motor hydraulic cables! Does everyone cut out slots or something?
I feel the frame that holds the parcel shelf on the left will not fit over these cables
- Ducklakeview
You would have been getting an orange light when you pressed the "lower" button. This indicates that the shelf is up, or not fitted, and is a safety measure.
Mike
Mike
That's exactly it Mike, good to know. Thanks!
Mine's connected and spinning, don't think it has enough oil in it though. Roof unlocks but doesn't actually move.
Even though it's still not fixed I'm feeling great just to have the bugger out and re connected! Very satisfying after so many rude words and shouting at damn cable ties haha!
