I need to put the front end on axle stands but have a dilemma. The only acceptable place I can find to place my trolley jack is under the plastic jack carriers at the front of the sills. But when I jack it up from there, I can't find a suitable place to put the axle stands. I would usually place jack under the front cross member, then put axle stands under the jack pads. But the z has what appears to be an aluminium shield under the rear of the engine which covers the cross member and would get damaged.
The rear of the car I find simple, trolley jack under the two bolts on the diff, then jack up and put the axle stands under the two rear plastic sill jack carriers..
Best way to put front end on Axle stands
- Magicarcher
Z4 3.0L 2005. Titan Silver. Audio Upgrade Second Stereo Pioneer X8700DAB, Sony Xplode 4 x 70W Amp, 6.5" Reckhorn Subs in rear cubby, Focal AS165-3 in fronts.
- Silverzedtom
Jack up one of the rear side jack points, high enough to get a jack stand under the front point on the same side, repeat on other side and reverse to get her back down.
E85 2.5si
F55 Cooper S
F55 Cooper S
- Magicarcher
cheers, will give that a try
- Rusky
+1. Best waySilverzedtom wrote: ↑Tue Nov 14, 2017 8:38 pm Jack up one of the rear side jack points, high enough to get a jack stand under the front point on the same side, repeat on other side and reverse to get her back down.
3.0l Silver SMG, whippy and ginge fringe/ Sound gen mod/ Media bridge fitted (bluetooth and audio streaming) / Clear third break light/ Hard Top/ Eibachs springs and DLV back box/ Roof motor in the boot/ plus lots more.
- Steve84N
Make sure you're using wheel chocks though as the car twists all over the place without them.
C63 AMG Estate 6208cc
- Buckz
