Ignition switch swap
I'm going to change ignition switch today to see if non-starting issue is that. Do I need to disconnect battery at all? Cheers
Mineral grey E89 2.0M sport 2015
I think its always best as a precaution to disconnect the battery when doing that type of work.
I had similar problem some time back and found various youtube clips that were helpful, similar unit on several BMW models.
Good Luck
Good Luck
- Ducklakeview
You don't need to disconnect the battery, just make sure the key is out. It's a 10 min job.
Mike
Mike
Ok I’ve changed the switch but still no starting. Thought I’d give the starter motor a whack but can’t find it! Where is it please?
All the pictures I see on the internet show it on the passenger side. Can you see it looking from above?
Passenger side, rear of the engine. You'll see where it's mounted, the motor itself sits under the intake manifold so it's a bit hard to spot first time. I've found you can only really see the mount, but there's plenty of space to get arms in near it.
First time I looked I set my phone to video mode and stuck it in the gap between the engine and the strut tower/electrical box, quite clear to see then
Thanks. Found it! Whacked it as much as possible whilst my wife turned key. Almost cranked enough to start a couple of times but not quite enough. So looks like a new starter is required. Will start searching now. Hard to see, how many bolts hold it on? Cheers
- Yorkie Z
I believe it's 3 bolts if I remember correctly. It's only about an hour to change. Just be patient as it's a little tricky to reach
A Dirty M///
2 nuts holding wires on, 10mm and 13mm I believe, and 2 E12 bolts holding it to the casing. You can see the E12 bolts from above, they screw in towards the engine from firewall side.
Thanks for advice. Starter is ordered and I'll give it a go.
Depends on your engine, if you have N52 there are two and they are Ali torque + angle and single use.
Yes i have the N52 engine. Anyone replaced starter motor without taking loads of stuff off first? Scooba_Steve Steve, you saying I need to chuck them and get new ones? I imagine they're special and hard to find?!
