LED numberplate lights
- JDM
Just wondered if anyone can recommend the best place to get these from. Is it best to go replacement bulbs or the whole new unit? Ive done a search but things are a little unclear and its making my head hurt!!
04 3.0SE Roadster, 07 3.0Si Coupe, 12 2.0iSdrive M Sport... Gone but not forgotten
Now proud owner of an Audi TT TFSI S line, Misano Red Amplified black edition... Don't shoot me.
- aquazi
Re: LED numberplate lights
i changed mine, with some led bulbs.... you will need to either get wedge ones, or dremel the lip off the normal ebay type.. as the hole on the stock holder is very small.
BMW has LED replacement lights which are a direct fit on the z4 if you change the connector.
Part n. 63 26 7 193 294
Part n. connectors : 61 13 8 365 340
total cost £23 delivered from Joe at Soper, and it took me 10min to install it
http://wouter.shush.com/wordpress/wp-co ... ds/LED.pdf
- JDM
Thanks for the responses..
Think I prefer the idea of the replacement BMW unit as you will get the guarantee / warranty etc.. Also its a BMW part above all else.
Looking at the instructions, is there some soldering required? I bought some from BMW for my 1 series and all you had to do with that was snap off one of the little lugs on the existing connector so that i snapped into the new unit. Take it this not possible on the Z?
There is no soldering required. You just have to pull off the cables form the old connector and insert them in the new one. The connector costs £1-2, so not worth to try to adapt the old one.
- JDM
Thanks for the info.. Just contacted local stealer and its £10 + VAT per fitting and about £5 + VAT per cable and connector so about £30+VAT all in. Ill contact Joe at Sopers and see what he quotes. Be interesting to see as my local wont budge on that price!
LED numberplate lights??? I like the sound of it
Anyone got a pic of this mod???
2007 Z4 Coupe, Montego Blue, black leather, heated seats, pro sat nav, xenons, 108's, cruise control, voice activated bluetooth, comfort pack
- JDM
Ordered from Joe. £23.52. I'm in Lincoln next week in business so I'll pick up then
I used these;
http://www.autobulbsdirect.co.uk/501-LE ... right.html
Works like a treat and look just like the newer bm's with led number plate lights.
Just ordered mine £22.88 cant wait............Joe's a good fellastef787 wrote:BMW has LED replacement lights which are a direct fit on the z4 if you change the connector.
Titanium Silver roadster, Mods: MV3's Stubby, M Steering Wheel, Cruise Control, Chrome exhaust tips, carbon fibre grilles, remote hood, Loads of wax!
- JDM
Erm, why were yours cheaper? awwww bet its coz you have a roadster and he felt sorry for you.z4alfie wrote:Just ordered mine £22.88 cant wait............Joe's a good fellastef787 wrote:BMW has LED replacement lights which are a direct fit on the z4 if you change the connector.
- JDM
Z4 Alfie, tried fittin these but can't seem to sort it. All I got from Joe was the bulb units and two plastic connectors. Lookin at the instructions you posted it seems to show two wires plugging into the new connector. Are these the exidtind wires that are pulled out of the existing plug or are they new wires that should have been supplied by Joe? If it's the existing wires then I can't seem to pull them out of the existing plug. They are well and truly in there?
Any help is appreciated.
- JDM
Stef787, tried fittin these but can't seem to sort it. All I got from Joe was the bulb units and two plastic connectors. Lookin at the instructions you posted it seems to show two wires plugging into the new connector. Are these the exidtind wires that are pulled out of the existing plug or are they new wires that should have been supplied by Joe? If it's the existing wires then I can't seem to pull them out of the existing plug. They are well and truly in there?
will these also fit the 2004 roadster?
- pvr
JDM, I have not installed those, but have dismantled the BMW connectors before for other projects. You usually have to use a small screwdriver to push the connectors (the small one) out of the connector they are house in so you are left with the wires with the metal bits connected to them.
Insert those wires and metal bits into the new connector.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
