I've bought two OEM fog lamp covers.
51 11 7 158 835
51 11 7 158 836
http://www.bmwstore.pl/pl/katalog/diagram/51_5929-obudowa-zderzaka-przedniego/vLZ31262#part03
I've also purchased OSRAM DRLs - the Light@Day model, the only set which does not rely on chavvy spots of light but on the light guide technology. The result is an even line of light, not a cheap Christmas Tree festival.
Had the covers cut to measure and the DRLs wired by a local indy.
The final effect:
The DRLs light up when I start the engine and go out when I switch on the lights. The control module detects alternator cycles and a trigger wire is connected to the headlights. The only drawback is that - under extreme load, such as when parking - the electric power steering can fool the module for a second.
By the way, my fogs were pretty rusty, which explains the water ingress:
Mine were made by AL Autolighting and assembled in Mexico. The new replacement OEM fog lamps are made by Bosch, but I was unwilling to give them a chance.
I know the Endloesung is fitting an M-bumper, but it is a bit lower than the standard sideskirts, and I'm not in for the snow plough look.
51 11 7 158 835
51 11 7 158 836
The final effect:
