Cigarette Lighter problem ?
- easty027
Hello All.
my cigarette lighter doesnt seem to work anymore which makes it a real pain in the a$$ to use my radar detector, sat nav etc. I have taken out the centre console section and checked underneath for loose wires etc but everything seems to be intact. When i press in the cigarette lighter into the socket it clicks in then pops out as it should do but there is no heat on the cigarette lighter.
Is there a fuse for the cigarette lighter ?......if not does anybody have any other ideas that i could look into.
Thanks in advance.
Thanks in advance.
- sp3ctre
- Site Admin
Re: Cigarette Lighter problem ?
Yes there is a fuse, and i'd say odds-on that's what has gone. The fuses are located up behind the glove compartment. You have to detatch it slightly, then it flops down and you can get at the fuses.
- sp3ctre
- Site Admin
I believe the one you are looking for is number 5, a 15A fuse:
Quite why the Ozzy's have a different cigarette lighter fuse setup I don't know.... bigger cigarettes???)
- easty027
Thanks a lot for that, i will check tomorrow.sp3ctre wrote:I believe the one you are looking for is number 5, a 15A fuse:
2004, 53 plate, 3.0 Roadster, Sterling Grey
I need a fuse for my lighter. Still I am searching but can not find my specific one. If anyone have any information then please inform me. I need antic shop for iteasty027 wrote:Hello All.
Is there a fuse for the e cigarette lighter ?......if not does anybody have any other ideas that i could look into.
Thanks in advance.
Last edited by Gerard Anderson on Sat Apr 26, 2014 8:07 pm, edited 1 time in total.
- Wa'ya
Just a little heads up, I was having the same problem, it very well could be the fuse but if the lighter is popping up I bet your fuse will check ok. I removed the whole unit to do my garage door mod and found the connector to the lighter socket was covered in the green & white corrosion you find on a corroded battery post. I took some baking soda a drizzle of water and cleaned the connections with a brass brush and my lighter s working like a charm now.
http://www.ebay.com/itm/Battery-Disconn ... 35c93e505fGerard Anderson wrote:I need a fuse for my lighter. Still I am searching but can not find my specific one. If anyone have any information then please inform me. I need antic shop for iteasty027 wrote:Hello All.
Thanks in advance.
- AlanJ
Hey Gerard - welcome to the Forum
