Do I have xenon's?
- Steve84N
Do I have xenon's?
Fair enough, it works for telling on facelift then as mine have the reflector main beam.
C63 AMG Estate 6208cc
Do I have xenon's?
Hi All,
Sorry for taking ages, so I finally managed to get to the rear of my headlights and unfortunately I have Halogens
Anyway I changed the H7 bulb with a cheap £2 ebay replacement, started her up and back to normal now, although the lights didn't go up and down this time with the VRR VRR noise strangely.
I think from my experience, with all the signs everyone's given me, the only way to really be sure is it open up the headlight and see for yourself maybe, but you guys are right, i cant see anything in a country road!
Question is, do I get a HID conversion kit or try and find a HID headlamp uni from a breakers?
Black 2003 E85 Z4 3.0i (newbie)
Do I have xenon's?
HID kit over the conversion - to do it properly you'll need the lamps, ballasts, levelling sensors, new LCM (light switch) and coding. Very expensive even without new parts.
HID kit is essentially plug and play and is reversible.
- Roundozo
Do I have xenon's?
Agreed with the above post. I had halogen and couldn't see anything while driving at night. I've since fitted an HID kit and it's a massive improvement and a relatively simple job to do.
Fitting oem or even aftermarket xenon just isn't worth the cost outlay if you ask me due to all of the additional bits you will need to make it work properly.
Past - Z4 Coupe, gone but not forgotten
Present - 530d M sport touring
- Magicarcher
Do I have xenon's?
I too am confused if i have zenons. If I type my last 7 digits into the site which gives specs/accessories, no mention is made of my car having zenons. However My car is fitted with headlamp wash, and the lights say on them D2S H7. One light has a traditional parabolic reflector the other has a semi-spherical condenser lens.
Could anyone unriddle this for me, as I am confused.
Z4 3.0L 2005. Titan Silver. Audio Upgrade Second Stereo Pioneer X8700DAB, Sony Xplode 4 x 70W Amp, 6.5" Reckhorn Subs in rear cubby, Focal AS165-3 in fronts.
- k31ron
Do I have xenon's?
Which HID kits are you all fitting? Had enough of my halogen candles.
- mr wilks
Do I have xenon's?
Have you yellow hazard warning stickers under bonnet on the panel above each headlamp ? This is usually the giveaway for Xenon,sMagicarcher wrote:I too am confused if i have zenons. If I type my last 7 digits into the site which gives specs/accessories, no mention is made of my car having zenons. However My car is fitted with headlamp wash, and the lights say on them D2S H7. One light has a traditional parabolic reflector the other has a semi-spherical condenser lens.
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
OnlineMr Tidy
Do I have xenon's?
From what I have read the clincher is whether you have the thumbwheel to adjust the angle of the headlights next to the dimmer for the dash lights - if you do they aren't Xenons as they self-level, hence the up/down sweep if they are Xenons!
Headlight washers aren't at all conclusive - certain models (including all facelift 3 litre IIRC) have washers - the difference is if they are Xenons non-working headlight washers are an MOT fail, whereas on Halogens they are just an advisory AFAIK.
One thing is for sure, if you ever own one with them and one without you will know for sure! Sadly my current one is in the dark.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- Magicarcher
Do I have xenon's?
NoHave you yellow hazard warning stickers under bonnet on the panel above each headlamp ? This is usually the giveaway for Xenon,s
Have thumbwheels.From what I have read the clincher is whether you have the thumbwheel to adjust the angle of the headlights next to the dimmer for the dash lights - if you do they aren't Xenons as they self-level, hence the up/down sweep if they are Xenons!
Guess I don't have Xenons
- Roundozo
Do I have xenon's?
Not the end of the world. Not as expensive when they go wrong (some of the xenon's will be getting on in their years now) and you can modify them (Hid kit) so you get a lot better light output.Magicarcher wrote:NoHave you yellow hazard warning stickers under bonnet on the panel above each headlamp ? This is usually the giveaway for Xenon,s
Do I have xenon's?
Don't mean to hijack this, but just a curiousity. It seems the general consensus is that HID kits to replace the H7 halogens are okay, I assume this is because the halogens also have projector lights rather than reflectors.
I only ask as I'm looking for a Z4 myself right now and finding ones with all my options ticked is proving fruitless! If I can knock xenon off that list and fit a conversion kit then happy days!
- cj10jeeper
Do I have xenon's?
HID kits are never as good as OEM however are an acceptable solution for many to replace the poor lighting of halogenmjennings23 wrote:Don't mean to hijack this, but just a curiousity. It seems the general consensus is that HID kits to replace the H7 halogens are okay, I assume this is because the halogens also have projector lights rather than reflectors.
The reality is the size, shape and position of the bulb is not correct and at best don't dazzle and the light beam is OK to pass an MOT
If you can find a car with oem xenons it will be much better having the correct suspension sensors to adjust beam angle under load, alignment of beam with left 'flick' and cut-off and washers
