Anybody diy refurbed 108 split rims?
Anybody done a diy on the 108 split rims?
I'm doing a set at the moment with tips from Mr wilks, I have spent £20 on rattle can's and will then do them in the dark with a bag over my head. This is a tried and tested way apparentlyepsilon wrote:Anybody done a diy at home using wet and dry, metal filler etc on the 108 split rims?
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Ducklakeview
Am tempted to do mine once I get my CSL reps, to recoup some of the cost lol..
Mike
Mike
How did they turn out?firebobby wrote:I'm doing a set at the moment with tips from Mr wilks, I have spent £20 on rattle can's and will then do them in the dark with a bag over my head. This is a tried and tested way apparentlyepsilon wrote:Anybody done a diy at home using wet and dry, metal filler etc on the 108 split rims?
- mr wilks
Haha the Op on that thread was planning to do them whilst bolted together at least you have your set apart & if you have the time & the skills no reason why you won't have a decent end product for a whilefirebobby wrote:I'm doing a set at the moment with tips from Mr wilks, I have spent £20 on rattle can's and will then do them in the dark with a bag over my head. This is a tried and tested way apparentlyepsilon wrote:Anybody done a diy at home using wet and dry, metal filler etc on the 108 split rims?
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Work in progress at the moment. These were going on my car, but now have 107's on it. I will probably sell the 108's once done.epsilon wrote:How did they turn out?firebobby wrote:I'm doing a set at the moment with tips from Mr wilks, I have spent £20 on rattle can's and will then do them in the dark with a bag over my head. This is a tried and tested way apparentlyepsilon wrote:Anybody done a diy at home using wet and dry, metal filler etc on the 108 split rims?
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
I forgot to ask what type of bag I neededmr wilks wrote:Haha the Op on that thread was planning to do them whilst bolted together at least you have your set apart & if you have the time & the skills no reason why you won't have a decent end product for a whilefirebobby wrote:I'm doing a set at the moment with tips from Mr wilks, I have spent £20 on rattle can's and will then do them in the dark with a bag over my head. This is a tried and tested way apparentlyepsilon wrote:Anybody done a diy at home using wet and dry, metal filler etc on the 108 split rims?
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Rialas
Ooohh not a job I'd like to attempt.
Mine going in Monday to get them back to original diamond cut edge.
That won't last long!Rialas wrote:Ooohh not a job I'd like to attempt.
- Ducklakeview
+1Scooba_Steve wrote:That won't last long!Rialas wrote:Ooohh not a job I'd like to attempt.
I can imagine the mating area between the two pieces to be a b'stard of a water trap, and with the slight flexing that takes place, with subsequent corrosion following shortly afterwards..
Mike
Well worth trying a thin bead of clear silicone sealant in there.
- mr wilks
Ive taken a couple of sets apart that have obviously had a silicone bead & imo it could actually make the problem worseScooba_Steve wrote:Well worth trying a thin bead of clear silicone sealant in there.
Without it any water sitting between rim & star can effectively escape but if you apply a silicone bead any water that does get in is virtually trapped
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Nightmare these things, what about on the other side of the star too?
- Rialas
Not with my parkingScooba_Steve wrote:That won't last long!Rialas wrote:Ooohh not a job I'd like to attempt.
Hope lepsons have a decent method to avoid them messing up too soon.
Fingers crossed for you
My refurb plan will be silver rim and slightly darker stars to give a similar contrast but without the risk. Unless yours lasts!
