Z4 coupe,which new top mounts ?
Hi all looking at upgrading the suspension to the b12 kit and should really change the suspension top mounts front and rear. Scrolled through a few threads but can't really see and advice on branding of new top mounts or links to buy them. Before I go to the " sealers " has anyone got and advice which to buy online with any internet links
Kind regards
Kind regards
Meyle is very good Meyle HD even better
I used OEM
if you dont go OEM make sure you use the reinforcement plates!
///M|Silver Grey|Black Leather|BT|Nav|DSP|Heated Seats|PDC|Stubby|Turner Limiters|Turner Rear Top Mounts|Bilstein B12|Powerflex ARB Bushes|Powerflex Lollipops|M-Track|
SOLD
SOLD
Which brands oem ?VRSteve wrote:I used OEM
BMW is OEM.M1ghty_m0use wrote:Which brands oem ?VRSteve wrote:I used OEM
What I mean is if you go for a smaller adjustable top mount make sure you use re-enforcement plates.
If you use a standard style or top mount then you don't need that.
SOLD
SOLD
- Steve84N
Lemforder is OEM.
Get this with the rear bump stops if you haven't already got new ones: http://www.ebay.co.uk/itm/MEYLE-BMW-E36 ... SwcF9UU4qn
If you have just get this: http://www.ebay.co.uk/itm/BMW-E30-E36-E ... SwstxVZFsI
The B12 ront dampers have an integrated bump stop.
For the front mounts don't get Corteco, get Lemforder which is OEM. http://www.ebay.co.uk/itm/2x-Suspension ... Sw-0xYfnBz
C63 AMG Estate 6208cc
Thanks so it's lenforder is oem NOT as in the previous post BMW, didn't think I was being stupid ! Thought it was lenforder or meyleSteve84N wrote:Lemforder is OEM.
And the rear which are listed, will fit the z4 as there listed for e36/ E46 ? I know a few parts are interchangeable between e46 and e86 's
- Steve84N
Yes they fit, I thought it said Z4 in the description too.
OEM = Original Equipment Manufacturer
BMW don't directly make most of their parts, Lemforder is the brand they fitted in this case.
I actually misunderstood your question. My reply was correct, if you buy over the counter, from BMW, its OEM.M1ghty_m0use wrote:Thanks so it's lenforder is oem NOT as in the previous post BMW, didn't think I was being stupid ! Thought it was lenforder or meyleSteve84N wrote:Lemforder is OEM.
Thats what I meant, stupid or otherwise.
SOLD
SOLD
Lemforder is poor......MEYLE is the one
