I had an inspection 1 done, new front rear wish bone bushes, two new horn units, brake fluid. All at a main dealer!!! I must be mad, but now the steering is absolutely perfect and I haven't had a horn like that for years
- Silverzedtom
Thought I'd jump on the band wagon and remove my washer bottle, give it a good old fashioned clean, clean the filter and put it all back.
Was pleasantly surprised to see only one tiny bit of black gunk in the filter, and a sparkling reservoir top to bottom. I used washing up liquid with good results. I did the work on Monday evening and filled to the brim with tap water. I Checked it's still brimmed today before siphoning out and putting a 20/50 mix of Halfords premium screen wash in.
I would highly recommend using gummy phledge on the filter rubber, and a bit on the hose connection just to keep the rubbers supple.
[IMG]http://i349.photobucket.com/albums/q363 ... rgmjim.jpg[/IMG]
E85 2.5si
F55 Cooper S
F55 Cooper S
- Silverzedtom
Wash, polish, wax, bumper gel on all exterior plastic, tyre gel, rainex and a good go over inside. Smooth as glass
E85 2.5si
F55 Cooper S
F55 Cooper S
- Ducklakeview
Fitted my new halo headlights, AND found where an annoying rattle was coming from..
Mike
Mike
- 1000rr
polished the headlights to remove some cloudiness, re-stained and re-finished the drivers seat bolster, added door pin surrounds to match the gear knob and hand brake, put my black with red piping mats in.
- Mr Tidy
Took it for an MOT and it passed.
Unfortunately it got 2 advisories for the rear brake pipes. It's where they pass under the floor just in front of the rear wheel. BMW put a plastic cover on them but it looks like it may just catch road crap!
Now I need to work out how to get under the car with no garage or decent jack (I've already got the Hammerite as my E46 had a similar problem last year)!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- ronk
I can't understand why manufacturers still use steel brake pipes - kunifer is the sensible alternative and especially so in such a safety import area.
It's an option I would tick even if it was and extra £100 on the order form!
- Paulr
Does that pin surround stop them rattling?
If you try and take a cat apart the first thing you have is a non working cat.
- Buckz
What did you use on your leather?1000rr wrote: ↑Mon Jul 03, 2017 5:49 pm polished the headlights to remove some cloudiness, re-stained and re-finished the drivers seat bolster, added door pin surrounds to match the gear knob and hand brake, put my black with red piping mats in.
- 1000rr
- 1000rr
[/quote]
Wakeson leather repair paint.
- Paulr
Mine do. Bloody annoying!
- patriot66
Unscrew the pins. Wrap a few turns of insulating tape around the pin so it fits snugly but doesn't bind in the hole. Screw back in place. No rattles !
- markeg
Took #108 for an MOT - flew through, no advisories. Not bad for a car on 118k and 13 years old..... so will give her some pampering this weekend
previous: Alpina Roadster S, #108: gone
current: MB C-class
"veni, vidi, velcro - I came, I saw, I stuck around..."
current: MB C-class
Great looking sorted z top bloke to boot
2004 z4 30i auto Toledo blue stubby Areo front back sideskirts and rear spoiler M/// MFSW DLV exhaust mod mma tips vanos overhaul 108s refurbed ram air scoop E46 M3 heated seats clear rear lights M/// sport black grills
