Steering Wheel Now Retrimmed and Old School IPod Adapter
Evening all
I regularly read, but rarely post on the forum as I typically have nothing to offer, however, on this occasion I do.
First of all I've been waiting on an 'M' steering wheel for the right price and to be honest, nothing really came up. So I decided to take the plunge and send my wheel to Royal Steering Wheels to be retrimmed and thickness padded out. Well £140 and 2 weeks later I received it back and honestly, I couldn't be happier. The service was great, communication great and finish is fantastic. Well recommended. Photo to follow.
Second, as the winter is passing and I'm prepping the car to come out of the garage, I realised I couldn't stick another summer of CD swapping.
My Zed came with a Dension media adapter and whilst it played an old iPod it wouldn't charge, so I wrote it off. Before removing it and going back to the CD changer this week, I decided to make a last ditch effort for a jukebox solution. I saw a Layen i-charge adapter on Amazon offering the voltage step down required when transitioning to the iPhone 3GS onwards. For £15 it was worth the try and hey presto....it works. I now have an old 16GB iPod nano in the glovebox, working and importantly charging. Photo to follow.
Hope this helps other people that have the same frustrations that I had.
- IMG_3105.PNG (158.08 KiB) Viewed 903 times
- Chris_D
You could also buy an mpow bt adapter which sits on top of ur layen adapter in order to enable u to stream tunes via bluetooth.
Been using this method and works a treat for listening to both tunes and radio via phone.
Only caveat for me is that the voltage adapter i'm using throws up a screen on the satnav display which i cant get rid of. No biggy tho.
Thanks for the tips and contribution OP. I like.
Has your steering wheel be covered with leather?
[quote="Gav897"]
/quote]
Where is this mystery charging point in the glovebox that you speak of? I can't seem to find one.
/quote]
Are you using the Aux connector here? Or something else. Very interested to hear how I can get a BT module that will charge as well as play tunes...Chris_D wrote:You could also buy an mpow bt adapter which sits on top of ur layen adapter in order to enable u to stream tunes via bluetooth.
- Chris_D
No. My zed came with the ipod prep which is basically just a cable with an i-connector and takes the place of the cd changer.idej_jedi wrote:Are you using the Aux connector here? Or something else. Very interested to hear how I can get a BT module that will charge as well as play tunes...Chris_D wrote:You could also buy an mpow bt adapter which sits on top of ur layen adapter in order to enable u to stream tunes via bluetooth.
The voltage stepdown adapter sits on the end of the cable and the mpow bt dongle sits on top of that giving streamability from any bt device.
sounds great.
https://www.amazon.co.uk/dp/B00V0CCAPU/ ... UTF8&psc=1
Thanks ChrisD. Only problem I have with a BT adapter is that I have the optional BMW adapter already for the phone function.
EASI85....it's perforated leather on the sides and smooth top and bottom. It's a really nice finish and feels quality.
Jedi...it's a Dension media adapter that plugs into the main connector on the rear of the radio. The Dension cable then feeds into the glovebox.
Hope this helps.
Hope this helps.
- Chris_D
I also have the BMW BT phone prep, which works for calling but doesnt work for streaming music to the hifi/headunit.Gav897 wrote:Thanks ChrisD. Only problem I have with a BT adapter is that I have the optional BMW adapter already for the phone function.
The Mpow is a device to enable streaming music via BT to the hifi.
Well..you've got me thinking now...I'm wondering if this will do the trick?Gav897 wrote:Thanks ChrisD. Only problem I have with a BT adapter is that I have the optional BMW adapter already for the phone function.
Hope this helps.
http://www.incarconnections.co.uk/bmw-b ... ector.html
- Chris_D
I was thinking about getting that one but it wont work with mine as mine has DSP and it's not comaptible.idej_jedi wrote:Well..you've got me thinking now...I'm wondering if this will do the trick?Gav897 wrote:Thanks ChrisD. Only problem I have with a BT adapter is that I have the optional BMW adapter already for the phone function.
Hope this helps.
Intravee and Dension make systems too but theyre a bit of a faff imo. the dongle works fine apart from the weird screen i cant get rid of.
- MACK
Another excellent job by Royals, looks great, congrats.Gav897 wrote:Evening all
Hope this helps other people that have the same frustrations that I had. IMG_3103.JPGIMG_3104.JPG
Your post did have me confused at first, I thought it was a M Sport steering wheel so couldn't understand why you were trying to hunt one down. Its only at a second glance I noticed the wheel is actually a standard (se) wheel with black trims. Looks good did you refinish them yourself?
Silver 05 3.0i SE
White E89 20i M Sport
Jacks work is first class and he is a top guy. Glad you are happy
My Cars
2021 X3 M Sport loaded with Tec
1974 Triumph TR6 in Mimosa Yellow
Gone but not forgotten
2008 Z4 3.0 SI Roadster
Sorry if I'm being an idiot (I'm not good with this sort of thing at all) - but where do you plug this end into? If this end goes into the Z then I can do exactly as you've done.Chris_D wrote:I was thinking about getting that one but it wont work with mine as mine has DSP and it's not comaptible.idej_jedi wrote:Well..you've got me thinking now...I'm wondering if this will do the trick?Gav897 wrote:Thanks ChrisD. Only problem I have with a BT adapter is that I have the optional BMW adapter already for the phone function.
Hope this helps.
- Chris_D
That side of the voltage adapter plugs into the female connector on the mpow bt dongle. reference my photo above and it's the component that sits in the middle of that 3 component string.idej_jedi wrote:Sorry if I'm being an idiot (I'm not good with this sort of thing at all) - but where do you plug this end into? If this end goes into the Z then I can do exactly as you've done.Chris_D wrote:I was thinking about getting that one but it wont work with mine as mine has DSP and it's not comaptible.idej_jedi wrote:
mpow bt dongle - voltage adapter - bt prep cable
Hi Mack
The trims are just the standard silver/chrome, trick of the dark surroundings. Thanks for the message.
