3.0si cruise control retro fit
LG Trimming
Post by LG Trimming » Fri Mar 10, 2017 5:16 pm
Hi guys,
Just a heads up. I've just fitted this cruise control retro fit kit. It works as it should, stalk is factory, loom is high quality and instructions are clear! (I contacted the seller regarding the instructions and he emailed it over in a PDF)
https://www.ebay.co.uk/itm/122372356064
This post is to reassure people who might be in doubt over ordering a kit from eBay, and from another country.
Unfortunately I didn't have time to do a how to, but it took me no longer than 40 minutes to install.
Lawrence
Buckz
Post by Buckz » Fri Mar 10, 2017 5:50 pm
bought one! :) thanks for sharing.
Any details on installation - or things that you feel could be done better than the how-to/pdf ?
Scooba_Steve
Post by Scooba_Steve » Fri Mar 10, 2017 6:00 pm
Scotchlocks... I prefer the BMW wiring loom with proper connectors on it.
LG Trimming
Post by LG Trimming » Fri Mar 10, 2017 6:27 pm
Buckz wrote:bought one! :) thanks for sharing.
TBH it was really clear and straightforward. He mentions cutting the wire to get through the bulkhead and take off some unnecessary length, but I didn't feel the need to. Also when working on the headlight block connector, get to this by under the dash/sheeting wheel (undo the clip securing the loom to the dash structure) as there isn't enough length through the dash aperture.
I did think that there was a blanking plate for the stalk in the steering column, but a rectangle needs to be cut through the plastic. It's made much easier by the outline being in the plastic on the outside. Plastic is soft enough. I drilled pilot holes in the corners then dremiled the straight lines. Bit of a sand/file to clean it up and it's ready to go. Stalk is secured via a sliding mechanism inside the column which is already there.
Easi85
Post by Easi85 » Fri Mar 10, 2017 7:27 pm
Thanks for sharing :thumbsup:
Tcochrane92
Post by Tcochrane92 » Sat Mar 11, 2017 6:00 am
All gone :thumbsdown:
Current: Imola Red 400bhp 640d & Ocean Blue BMW S1000XR Sport SE
Past: Silver Grey Z4MR, Silver Grey Z4C & Titan Silver Z4 3.0i
Scooba_Steve
Post by Scooba_Steve » Sat Mar 11, 2017 11:58 am
It's about the same price from Soper with the genuine loom...
Marlon
Post by Marlon » Sat Mar 11, 2017 12:47 pm
£128 from Sopers for stalk and loom
Gone: 3.0si 2008 E85
911 997 Carrera S
RyanB88
Post by RyanB88 » Thu Apr 27, 2017 3:44 pm
Has anyone else used this?
Z4 now sold :(
Current - M235i :thumbsup:
Tcochrane92
Post by Tcochrane92 » Thu Apr 27, 2017 8:14 pm
Do you have the fitting instructions?
Tcochrane92
Post by Tcochrane92 » Thu Apr 27, 2017 8:35 pm
85genius
Post by 85genius » Thu Apr 27, 2017 9:11 pm
Hmmmmm I've already got a stalk... Do I really need a loom or just sone spare cabling I haven't my garage will do?
Audi quattro driver :o
NOW SOLD - Ruby Black 3.0 SI Roadster :(
Previous - E85 2.5 Ti Silver - See avatar photo - R.I.P Destroyed by a Tranny
85genius
Post by 85genius » Thu Apr 27, 2017 9:12 pm
Or in fact any random cable I can buy from the electrical centre?
Scooba_Steve
Post by Scooba_Steve » Fri Apr 28, 2017 3:49 pm
The issue you will have is connectors. You will make 2 joins at the LCM, that could be done with scotch locks, BMW do some good ones. But you need the connector at the stalk and 3 or 4 pins for that along with a pin for the DME. I could make up a loom with some research but doubt it would be worth my time in the end.
Greg 01
Post by Greg 01 » Fri Apr 28, 2017 4:42 pm
Hi guys .
It may be a silly question :roll:
Can the cruise control be fitted to my 07 plate auto ? .
Cheers for any help :thumbsup:
Nachtblau metallic 3.0 si auto ,cup holders , whippy back on :thumbsup:
