Tramlining?
Tramlining?
Okay, a week and a half and 1000 miles under my belt, i've come to notice something that's bugging me about my new Z4C.
At high speeds on motorways: no problems.
At lower speeds, on a or B roads: the car just wants to go wherever the road says, not where I want it to. It follows cambers in the road and feels like it's floating along.
Now, I've checked the tyres, I have Vredestein Ultrac Sessanta's on the front (225/40/18). The tread depth is getting low and the inner side seems to be wearing a touch more than the outside. On the rear I have Vredestein Ultrac Vorti's (255/35/18) with plenty of tread and what appears to be consistent tread wear.
So the question is, is this a common thing? Is it due to low weight and low profiles, or is it that my alignment might be subtly out? Or do I want new tyres??
Many thanks.
Pete
Many thanks.
Pete
Tramlining?
I had similar problems with run flats, once I replaced them then no problems.
- RickRob
Tramlining?
I had exactly the same issue with mine when I got it. Worn, but legal, Vredstein Ultrac Sessantas (non-run flats) on the front and car determined to follow the road and not the steering wheel. Initially I thought that it was just what got with a stiffly sprung sports car.PTR101 wrote: ↑Wed Apr 26, 2017 7:37 pm Okay, a week and a half and 1000 miles under my belt, i've come to notice something that's bugging me about my new Z4C.
Many thanks.
Pete
However, I changed the fronts for Goodyear Eagle F1 Assymetrics and wow, what a transformation. (Subsequently changed the rears for the same. Good, but not much difference.)
Even Mrs R, not known for being the world's most "sympathetic" driver, noticed the difference. The downside was that Mrs R now drives the Zed a lot more than she did.
///M Roadster. 2007 Black/Black. Rear spoiler, whippy aerial, mud flaps and gimp-style wind deflector!
Tramlining?
I had the same issue, replaced front wishbone bushes has reduced it considerably but most cars with wide tyres do this to a greater or lesser degree.
Online
- Ewazix
Tramlining?
Your'e right, mine took some sorting switching from RFT's made a huge difference then bushes as you say, springs and several 4-wheel alignments later it's sorted. This is a good article showing just how many different factors are involved in tramlining
American article but tramlining is a universal curse https://www.tirerack.com/tires/tiretech ... ?techid=47
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
- mr wilks
Tramlining?
Unlikely to be the op,s solution as he's on Vredestein tyres which don't do runflats
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- mr wilks
Tramlining?
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- mr wilks
Tramlining?
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Tramlining?
I just did a quick google, it seems that there is a run flat option for the Sessanta, i'm not sure if I have it. I'll check tomorrow.
Otherwise, it seems a pretty clear course of action. I'll look into new tyres, get it booked in for alignment and have the bushes checked.
Thanks all.
Thanks all.
- mr wilks
Tramlining?
Really rarer than hen's shazzy i would expect
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Tramlining?
As above
Ms don't use nor come with runflats
But low tyres and that brand does seem to suffer on some cars
Is replace all tyres buddy with high end tyres as an M
And get a geo check
I love Mss
Only use on dry
So could use new mps4s or gyf1
And get a geo check
I love Mss
Only use on dry
- hopz121
Tramlining?
Check tyres too see if you have non run flats would be my first port of call, you want all tyres to be either run flats or not run flats ideally.
Next I would check tyre pressures 34 front, 36 rear I found works well.
Next I would check your rear trailing arm bushes and front rear wishbones bushes (lollipops)
If all these things are good I would go and have a proper 4 wheel alignment and hopefully that will resolve it, if you give people an indication of where you are based you may get some recommendations too. Most fast fit tyre centres like kwik fit don't do a proper job so worth going somewhere who knows what they are doing.
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
Tramlining?
Okay, checked this morning, there's nothing on the tyres to indicate that they are RF. I'll check the pressures before I go out tomorrow.
Thanks for all the great advice.
