Steering wheel
- Sgr74
- vester86
Steering wheel
Not any, but a lot from the same era do fit. Be sure you have/find one with a dual stage airbag. Most BMW switched from single stage to dual stage between 1999-2001.
Z4 use a dual stage!
Steering wheel
The e46 wheel fits, I had one in my Z4 .. its just a little bigger than the standard Z wheel
- Sgr74
- kis
Steering wheel
I've heard e46 and e53 will fit. It's easy to fit, pop the airbag off, and one bolt to undo. Oh and goes without saying you'll need to disconnect the battery. Not sure if you can wire them up correctly to make the MFSW work
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Steering wheel
That sounds like a TIS challenge!
Steering wheel
Would the MFSW work on my 2003 Z and what does it control ?
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Sgr74
Steering wheel
There is a how to thread on this. You can buy a retro fit cable from BMW.
Black 2.5 Roadie.
- vester86
Steering wheel
e46 sport wheel is same diameter as Z4 wheel, but thicker. feels 100x nicer, maybe best upgrade i've did
Steering wheel
Cheers, I was only asking because it appears most things on the very early E85's were pre-wired, you just had to add the switches or units.
I take it, the buttons work the stereo ?
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Steering wheel
MFSW - multi function steering wheel - buttons for the stereo
Z4 now sold
Current - M235i
Current - M235i
- vester86
Steering wheel
yes buttons on the left do stereo (volume + track/radio change).
buttons on the right control control Cruise control but i have to wire that (haven't done it yet)
Steering wheel
I assume the cruise will work the same on the E46, i.e. one wire takes the signal, if so just need to find the pin on the wheel and run the pin from the cruise stalk connector to it.
- paddy wright
Steering wheel
Your car will be prewired- easy retrofit
- Steve84N
Steering wheel
Nope, it's bigger by about 20mm. Having had an e46 and a Z4 with the M Sport wheel they are about the same in thickness, although compared to a standard Z4 wheel it's thicker.
C63 AMG Estate 6208cc
