Springs
Simon Blythe
Springs
Post by Simon Blythe » Thu May 18, 2017 8:34 pm
Left hand Spring - M Sport
Right hand Spring - came on the car
Steve84N
Springs
Post by Steve84N » Thu May 18, 2017 8:57 pm
And?
C63 AMG Estate 6208cc
D4dawg
Springs
Post by D4dawg » Thu May 18, 2017 8:58 pm
Erm
Point being ? Haha
Scooba_Steve
Springs
Post by Scooba_Steve » Thu May 18, 2017 9:41 pm
:tumbleweed:
kis
Springs
Post by kis » Thu May 18, 2017 9:44 pm
I think OP is pointing out that on one side he had a wrong spring fitted...
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
Marlon
Springs
Post by Marlon » Thu May 18, 2017 9:51 pm
Yeah, kis that was my thought - one seems longer than the other :?
Gone: 3.0si 2008 E85
911 997 Carrera S
Simon Blythe
Springs
Post by Simon Blythe » Thu May 18, 2017 10:05 pm
Yeah the left hand one is a spring I purchased on the forum, an M sport Spring and the right hand spring is what's on the car. I'm assuming the right hand one is either aftermarket or an SI Spring?
kis
Springs
Post by kis » Thu May 18, 2017 10:36 pm
M spring is a difference of 15mm I think. The other spring is just a standard spring. Not all Zed's came with M springs... both probably correct OEM sizes, just different setups. And obviously need to both be the same, so both either standard or both M
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Simon Blythe
Springs
Post by Simon Blythe » Thu May 18, 2017 11:05 pm
Which set would you guys fit?
kis
Springs
Post by kis » Mon May 22, 2017 1:32 pm
If I were to do it again? Eibach and fit some spacers. Will give you whatever height you want... See this.
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Artful-Bodger
Springs
Post by Artful-Bodger » Tue May 23, 2017 7:43 pm
The shorter spring is the stiffer one, so it depends what's on the front, you need to balance it?
A spring is basically a steel rod wound into a coil, the longer the rod the more it flexes (is softer) for a given load, if you try to bend a 10mm steel rod that's 500m long it's extremely stiff, now bend one that's 2000mm long and its far more flexible, it's the same with a spring, the less coils (rod length) the stiffer it is for a given diameter of steel.
Rules are for the guidance of wise men and the blind obedience of fools - Colin Chapman
Ewazix
Springs
Post by Ewazix » Tue May 23, 2017 8:03 pm
I was a bit mystified when I bought standard (non-spot) Sachs replacements for my std (non-sport) rears as the Sachs were a bit shorter. The OEM springs are dual rate with much thinner sections at each end, most aftermarkets are not but are slightly shorter and thicker off the car and not compressed. But once fitted and compressed they sit pretty much the same height.
I've found that the Sachs are slightly stiffer than the oem but not drastically. I suppose the aftermarkets are cheaper to make but a benefit is that they are less likely to snap as it's usually the thin'tails' that rust and break on the oem 'turkey twzizlers' :D
2018 Cooper S Countryman
Fiesta Ecoboost
