Original Wheels
Original Wheels
I've recently bought a 2.5Si..I'm fairly certain the wheels it has on aren't the originals..is there any way I can find out would the car would have left the showroom with when it was first bought?
- Lynchy
Original Wheels
Post a picture and someone will tell you
Original Wheels
Go on BMW vin .com put in vin and you should get full spec from manufacturers
2004 z4 30i auto Toledo blue stubby Areo front back sideskirts and rear spoiler M/// MFSW DLV exhaust mod mma tips vanos overhaul 108s refurbed ram air scoop E46 M3 heated seats clear rear lights M/// sport black grills
- kis
Original Wheels
You've got CSL wheels (may be reps). Good wheel and suit the car really well! Not sure what you would have had as standard - but it wouldn't have been those wheels! Maybe the car originally came with 107 or 108's!
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Original Wheels
mine came with 103 from factory just depends on customer choice
Original Wheels
Apparently it came with Msport double spoke 135...I assume 18" although it doesn't give the wheel size...does that sound about right..?
- Darkangelv2
Original Wheels
135 = MV2 I believe so yes 18"
BMW Z4 2006 2.5SI - 437M Wheels - Strut Brace - H&R ARBs
3.0si Brake Conversion - Custom Nappa Sport Interior - Z4M Bumper+Bonnet -
BC Racing BR Coilovers - AFE Stage 2
- Silverzedtom
Original Wheels
It most likely did have the style 135 'MV2' wheels:
8.0" et47 on the front
8.5" et50 on the rear
E85 2.5si
F55 Cooper S
F55 Cooper S
- Fox889
Original Wheels
Very interesting, didn't realise you could do this, & have just done it!
Under 'vehicle options' does this mean what you "could" have had if you wanted or what you actually "have" had?
Makes interesting reading & thank you for the link.
2004 3.0 Z4 in Sterling grey metallic
Original Wheels
it shows what it was fitted with when it left factory
Original Wheels
OK thanks very much ...what are people's thoughts regarding the different wheels ie CSL reps or original 135's?Silverzedtom wrote: ↑Mon May 22, 2017 11:43 pm It most likely did have the style 135 'MV2' wheels:
- Fox889
Original Wheels
[S704] M Sports suspension...........is this normal?bz4kev wrote: ↑Tue May 23, 2017 8:56 amit shows what it was fitted with when it left factory
Original Wheels
it is on the 3.0 models I was shocked too but yes I believe all 3.0 models were treated to this
