I've just fitted Matt black grills and this has highlighted the support strut behind them needs a lick of paint.
Can I just remove this (through the grills) or do I need to prop anything up?
Would hammerite be ok as it's an ally bar?
Front support strut through the grill.
- dhobbs
3.0si roadster. Requisite stubby. Sound gen mod. LED numberplate lights. LED boot strip. Interior lights LED too. ZHP gearknob. Daily drive
Motor in boot. Bilstein B8 dampers. New radio, much better sounds
- patriot66
I gave my support struts a light sanding and sprayed them with satin black spray in situ through the grille apertures.
- dhobbs
You're a braver man than I!
I started picking at the paint and it all fell away from behind it too.
