My steering wheel refurbishment
- Marlon
Looking great - good work there
I struggled like hell removing the air bag first time - like you I almost gave up, as mentioned its knowing where to push and how much pressure.
I plasti-dipped mine - mistake! It rubs up too easily, thought it would be ok cos I have no buttons but will have to take them off at some point and spray as you and srhutch have.
Gone: 3.0si 2008 E85
911 997 Carrera S
[IMG]http://i1280.photobucket.com/albums/a49 ... jor7wl.jpg[/IMG]
Mine with new wheel t pieces
With the usual I thought button covers came with it. No!
Then Bryan diet coke swapped out my buttons for some he had already refurbed and outcome
Awesome:)
Awesome:)
- 85genius
All back together, I've got a couple of notes about the process but I'll write them later I want to go enjoy the sunshine now
[IMG]http://i1375.photobucket.com/albums/ag4 ... ihmgnp.jpg[/IMG]
Audi quattro driver
NOW SOLD - Ruby Black 3.0 SI Roadster
Previous - E85 2.5 Ti Silver - See avatar photo - R.I.P Destroyed by a Tranny
- Marlon
Very neat - well done, great work James
911 997 Carrera S
- 85genius
Appreciate the comments guys! Really happy with the outcome its such an improvement over what I had...
So on to the notes about the process and what I'd change if I was to do it again....
I'll start with the paint, this is what I used http://www.ebay.co.uk/itm/262623852897? ... EBIDX%3AIT To say it was difficult is an understatement! The finish was decent but actually using the rattle can was a massive PITA!! Normally with a spray can you just use your index finger on the nozzle but my can was so stiff I had to use 2 hands and was pressing with my thumbs to be able to put enough constant pressure down on the nozzle to get the paint to come out smooth.
I did just re read the advert and saw that they state in the listing "To achieve an even better finish and eject more paint from the can, consider a spray gun trigger (Available in our eBay store)" and to be honest I didn't take any notice of that when ordering but now it makes sense, although probably should have read "this stuff is a bloody nightmare to use unless you buy a spray gun trigger" So thinking about it I would probably uxe this paint again, but absolutely no chance Id even try without one of these
http://www.ebay.co.uk/itm/Spray-Paint-A ... Swax5Yy9m2
Also trying to get it all done in a day is probably not the best idea, there are a couple of minor imperfections one from dust lading on the paint before it was touch dry and another from a little bit of splatter before I realised I needed top hold the can with 2 hands and use both thumbs. I would really have liked to be able to very lightly sand again on those areas before the next coat but I was going out at 6pm and needed the car the following morning so just didn't have time.
Also on spraying, I definitely made it more difficult for myself around the edges by having the pieces flat on the surface, I could have made some little stands with cardboard and stuck the parts to them with blutac to raise them up to make the edges much easier to coat smoothly.
Also I wasn't careful enough removing the masking tape, I lifted a tiny bit of the finish around the //M badge I touched it in by spraying some paint directly into the lid of the can and using a very fine paint brush but could have been better if I'd just been more careful...
All in all though really happy with the result for a total of £4.49 spent using a few other bits I already had in I have made a massive improvement to my cars interior, just wish I'd known to spend the extra £2.70 on the gun attachment
Audi quattro driver
- 85genius
And a slightly better photo as the last one was with the top down
[IMG]http://i1375.photobucket.com/albums/ag4 ... drxlaq.jpg[/IMG]
Audi quattro driver
- blackabbot
Great Job, now I will have to do got to do mine
2008, E85 2.0i sport, Titan Silver, Hardtop, ZHP Gear Knob, Chrome Exhaust Tip , Hydro Graphic Carbon Interior, DLV roof motor relocation and CDV delete and a Whippy
- Silverzedtom
Looks good guys. Mine are looking tatty. I keep putting it off as I'm scared of the airbag. This has given me motivation though
E85 2.5si
F55 Cooper S
F55 Cooper S
- z4pilot
This is a job I'm going to have to tackle at some point. Was removing the M badge not an option? I'm presuming you could then either refix with glue or double sided tape, or buy new (if available anywhere)?85genius wrote: ↑Mon Jun 19, 2017 2:38 pm Also I wasn't careful enough removing the masking tape, I lifted a tiny bit of the finish around the //M badge I touched it in by spraying some paint directly into the lid of the can and using a very fine paint brush but could have been better if I'd just been more careful...
Now Gone - 2008 Coupe, Montego Blue, Champagne leather and Piano Black interior, Eibachs & Koni Sport shocks, Style 230 19s, Eisenmann Quad - approaching perfection...
- 85genius
I did consider removing it but its such a small space to fit it in any paint build up could have made it not fit right also was worried about sticking it back and glue coming out of the sides and ruining the finish... Double sided tape I wrote off as I thought it would end up with the badge dropping off...z4pilot wrote: ↑Thu Jun 22, 2017 9:25 amThis is a job I'm going to have to tackle at some point. Was removing the M badge not an option? I'm presuming you could then either refix with glue or double sided tape, or buy new (if available anywhere)?85genius wrote: ↑Mon Jun 19, 2017 2:38 pm Also I wasn't careful enough removing the masking tape, I lifted a tiny bit of the finish around the //M badge I touched it in by spraying some paint directly into the lid of the can and using a very fine paint brush but could have been better if I'd just been more careful...
I was working on a guess its the same size as a alloy wheel M badge but that was just a guess I saw a few others had masked for refurb and got good results so I just copied that
Audi quattro driver
Chap could you let me know which paint you used, as well as which soft touch lacquer? First time I've heard of the stuff...
- MrPT
Great job. I've bought everything needed to do mine - hopefully in the next couple of weeks. Gone with vinyl primer and bumper paint to try and get the most durable coating I can. Also interested in the soft touch lacquer though.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
