Roof motor
Roof motor
Hi
I haven't bought my z4 yet but I am currently looking at 2 in my area.
I have read that the roof motors fail quite a lot is they anyway I can check this on the vehicles before I purchase
What do I need to look out for
- obewan
Roof motor
I think the only check is to try it and see if the operation is smooth and reasonably quick - it should be in the 8-10 second bracket.
You maybe be lucky and find it's already relocated to the boot by a previous owner
With the experts on here its' not the major expense it used to be as people have found ways to replace without removing the roof
Good luck with your search
E89 2.0 SDrive MSport
Honda CB500F.
Gone but not forgotten E85 2.0 MSport
Honda CB500F.
- srhutch
- Moderator
Roof motor
Yes, not the fear it once was so I wouldn't worry about it too much.
- Number5
Roof motor
Stop it mid cycle and then start it again in either direction. That's a good test to indicate the strength of the motor.
Also check it latches right down on the rear bulkhead when it's open.
Ask the owner when heblast cleared the drains and ask him how he did it and to point to where they exit. (About 3-4 inches in front of the rear wheels)
If he starts waffling you'll smell a rat.
Alpina Roadster #307
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
10x E85 Se/Si Roadsters
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Roof motor
Stop hood half way and pour water round edge
If none comes out in front of rear wheels
You have an issue
You have an issue
- srhutch
- Moderator
Roof motor
Not all Zeds have the latch. It was removed around facelift time, but some pre facelift owners have removed to stop it rubbing on the roof lining, which is what I have also done on my ///M.Number5 wrote: ↑Sun Jun 18, 2017 9:14 am Stop it mid cycle and then start it again in either direction. That's a good test to indicate the strength of the motor.
- Pastry
Roof motor
[quote=Number5 post_id=1435399 time=1497773668 user_id=14788]
Do they all 'latch down'? When I saw d4dawg his felt like it mechanically fixed down but mine and Dietcokemans doesn't?
991 Carrera 2S
Now gone:
2010 Z4 23i Msport and a 3.0i
Now gone:
- Pastry
Roof motor
Scrap my last question Number5srhutch wrote: ↑Sun Jun 18, 2017 9:38 amNot all Zeds have the latch. It was removed around facelift time, but some pre facelift owners have removed to stop it rubbing on the roof lining, which is what I have also done on my ///M.Number5 wrote: ↑Sun Jun 18, 2017 9:14 am Stop it mid cycle and then start it again in either direction. That's a good test to indicate the strength of the motor.
991 Carrera 2S
Now gone:
Now gone:
Roof motor
But nothing major, just a blocked drain
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Roof motor
Not if it's moved to the boot, it's a good bargaining tool if the roof isn't working though as there are plenty on here that can revive them
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Ducklakeview
Roof motor
Tbh, I wouldn't worry about the roof operation if it is working. Relocating it however, is a wise move once you have bought one. As said, it's not a big job, takes me about 30 mins. Even if they fail, they CAN be brought back to life in about 15 mins and then go on to perform perfectly.
Mike
Mike
Roof motor
Thanks for all the advice guys.
The only problem if it needs sorted is I am in Northern Ireland does anyone know if there is someone here can sort it
Roof motor
Can the motor be replaced or moved without removing the top and if not is it a big job
