Keeping calipers/inner wheel clean-
- andysat
Hi all-is there a 'clever' way to clean calipers/inner wheel rather than spraying a hose/high pressure washer on them?-I recently had one stick and I am blaming myself for spraying a hose through the wheel probably causing crud to go over the caliper-thanks
Gone but not forgotten.
New ride silver e93.
- GAZA62
Ive been blasting a hose in there for 9 year with no probs not a high pressure just regular garden hose.
I use a mit and various brushes and its done everytime I wash the car and they still look like this after a refurb few years ago.
T.SILVER 2004 3.0SE AUTO
IF IT WAS NOT FOR BAD LUCK I'D HAVE NO LUCK AT ALL
- andysat
- buzyg
big wheel brush, then detailing one for calipers n bolt holes and a dodo juice wheel nut plug for big nut holes
- patriot66
A selection of Wheel Woolies Brushes, a bucket of suds and a hose pipe is all you need.
http://www.theultimatefinish.co.uk/whee ... Atuy8P8HAQ
- GMANLAW
Liking those clips on the calipers where did you get them from?
Wrapped Magnetic Burst SI Sport Coupe....Good Spec plus M Front and Rear Bumpers, M Bonnet, Quad Exhaust, Aeroskirts, Drilled front and rear brake discs, 326 19's ZHP knob and obligatory Stubby!
- GAZA62
They were bought on here many moons ago from one of our US Cousins I fancy a set powder coated in gloss black.
- ESP
Same as GAZ, i make a point of blasting them with a hose/jet wash and never had this issue. Must just be bad luck?
Are you sure it wasn't a broken seal on the piston?
07 Sapphire Black Roadster.
