Is it an si?
Is it an si?
Is there any way of visually checking to see if the car is the si version? I've seen one I'm interested in buying, and advert says it's the si, however looking at pics where it has the writing on side by indicator it says 3.0 i.
- enzed4
Is it an si?
Difficult to tell as it may have been modded to add Si type features.
Check for m-sport seats, MFSW in black with the ///m logo, and the 135m wheels which I think were usually specced on the Si models.
Only way for sure is to put the VIN into a BMW vin decoder. If you're lucky it will also have the 'vin displayed on dash' option (or whatever its called), as mine does, which allows you to see the VIN from outside.
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
- mr wilks
Is it an si?
What year registration is it ?
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- enzed4
Is it an si?
Of course - good point. If it's pre-2006 it won't be an Si
Gone: 2010 35i DCT
Is it an si?
Look at the engine cover - a 2.5/3.0si has the N52 engine that looks completely different to the earlier M54 engine (large silver cover up to late 2007 and then black cover thereafter).
If it's a coupe then it can only be an facelift model, I.e. Si.
Facelift models will also have white indicator headlights, rectangular front fog lights, no body coloured bar across rear lights and different lense pattern, etc.
08 Z4 3.0si Sport Coupe in Montego Blue
OnlineMr Tidy
Is it an si?
As has been said, Coupes are all Si's.
The change came with the facelift in 2006 I believe, but even facelifts have the 3.0i badge!
Can you find a dip-stick under the bonnet? - if not it is an Si with the N52 engine and 265bhp, but if you can it isn't an Si so has the M54 engine and 231 bhp!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- Smartbear
Is it an si?
My si had badges that said "3.0si"?Mr Tidy wrote: ↑Thu Aug 24, 2017 12:18 am As has been said, Coupes are all Si's.
e85 3.0si sold
- srhutch
- Moderator
Is it an si?
That only works with the 3.0 which I guess the OP is talking about.Mr Tidy wrote: ↑Thu Aug 24, 2017 12:18 am As has been said, Coupes are all Si's.
Same can't be said about the 2.5 as they both use the N52 but only one is an Si.
- srhutch
- Moderator
Is it an si?
You are confusing Si which is an engine designation to a trim level which would either be SE or Sport.enzed4 wrote: ↑Wed Aug 23, 2017 9:18 pm Difficult to tell as it may have been modded to add Si type features.
- Smartbear
Is it an si?
Even that method is full of vagaries as my 3.0si was an se but had all the sport features mentioned above specced from new!srhutch wrote: ↑Thu Aug 24, 2017 6:47 amYou are confusing Si which is an engine designation to a trim level which would either be SE or Sport.enzed4 wrote: ↑Wed Aug 23, 2017 9:18 pm Difficult to tell as it may have been modded to add Si type features.
e85 3.0si sold
Is it an si?
It's an 03, so I guess it's not then
- srhutch
- Moderator
Is it an si?
I was just trying to point out that Si relates to the engine so it's easy.Smartbear wrote: ↑Thu Aug 24, 2017 6:59 amEven that method is full of vagaries as my 3.0si was an se but had all the sport features mentioned above specced from new!srhutch wrote: ↑Thu Aug 24, 2017 6:47 amYou are confusing Si which is an engine designation to a trim level which would either be SE or Sport.enzed4 wrote: ↑Wed Aug 23, 2017 9:18 pm Difficult to tell as it may have been modded to add Si type features.
SE vs Sport different ball game.
- kis
Is it an si?
Seller doesn't know! 2003 is pre facelift so M54 engine and definitely not an si. Not uncommon but worth giving it an extra check over? I'm speaking from a mechanical POV. My reasoning being an enthusiast would know if the owned a pre or facelift. He/she would also keep things up to date ensuring everything is looked after etc.
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- Buckz
- enzed4
Is it an si?
Not really. OP asked how to tell the difference (and now that we know it's an '03, the question is moot), and I pointed out the most obvious, easy to check clues. I'd be surprised if there were a lot of 3.0i Z4's specced with all of the Sport options, unless they had been retrofitted after purchase. Happy to be educated on this though.srhutch wrote: ↑Thu Aug 24, 2017 6:47 amYou are confusing Si which is an engine designation to a trim level which would either be SE or Sport.enzed4 wrote: ↑Wed Aug 23, 2017 9:18 pm Difficult to tell as it may have been modded to add Si type features.
I Also pointed out that the best way to tell was to check the VIN, and this should really be the first thing to check, thus avoiding all the debate.
Edit - sorry, I see what you're saying now. Yes, Si is the engine designation, and no indication of trim level.
Cheers.
Gone: 2010 35i DCT
