Brakes and Fluid Change Questions
Kugaman1
Post by Kugaman1 » Fri Dec 15, 2017 10:19 pm
Ah Ok, maybe that’s the way to go.....
Will probably do it next Feb/Mar when I take the winter wheels back off....
ronk
Post by ronk » Fri Dec 15, 2017 10:22 pm
I used to use a Gunson tool - fill the reservoir and cap it with an assembly connected to a reduced pressure spare wheel. As the nipples were opened the fresh fluid was pushed out.
Gaffa22
Post by Gaffa22 » Fri Dec 15, 2017 10:35 pm
Kugaman1 wrote: Fri Dec 15, 2017 10:19 pm Ah Ok, maybe that’s the way to go.....
Start with the brake calliper furthest away from the master cylinder and work your way round, a pressure system like the Gunson suggested by ronk will make it a bit quicker.
2010 E89 35i DCT
2017 Honda CBR1000RR fireblade
2016 Honda VFR1200F
ronk
Post by ronk » Fri Dec 15, 2017 10:46 pm
I’m not sure if they’re (gunson gizmo,s) are still available?
flybobbie
Post by flybobbie » Sat Dec 16, 2017 12:30 am
I thought Gunson disappeared the same time as Sparkright.
The sort of things you find at the back of your Dad's shed.
I liked the Spark Tune, i think it was called, where you could see through a glass spark plug to set mixture.
The Sparkrite solid state ignition ok until the power resistor dry jointed i my TR7.
Gaffa22
Post by Gaffa22 » Sat Dec 16, 2017 9:10 am
Yes the Gunson Eezibleed is still available
https://www.toolstation.com/shop/Automo ... lIQAvD_BwE
2010 E89 35i DCT
2016 Honda VFR1200F
bob4333
Post by bob4333 » Sat Dec 16, 2017 9:21 am
flybobbie wrote: Sat Dec 16, 2017 12:30 am I thought Gunson disappeared the same time as Sparkright.
'ere, I've still got one of those from the 1970's. Gunson Colourtune. Heavily used on my mk 2 Cortina GT :oops:
Still available from Machine Mart. Brilliant kit.
