Fitted BC coilovers, How do you code out adaptive suspension?
This weekend I have fitted BC Coilovers but now have the adaptive suspension fault warning/code. Does anyone know how to do this. I have tried to remove the 2VF from the VO but it is still there. Anyone done this or know how to do it?
I keep on getting the EDC module re-appearing even after VO coding out, do I need to completely disconnect this module?
Has anyone on here replaced adaptive suspension with Coilovers and can help me?
- NeilMick
Current - F31 330i & SLK 350
Previous - E89 35is
Previous E86 3.0si
Previous - E89 35is
Previous E86 3.0si
Thanks for the info but at over £300 I will try and find a coding solution and post a "how to" when I have done it.NeilMick wrote: ↑Wed Sep 27, 2017 7:32 pm Have you seen this kit?
https://www.ecstuning.com/b-kw-suspensi ... 510301~kw/
- DinosaurEyes
I have the KW EDC delete kit and either it doesn't work or it doesn't fully remove the warning but I still get the message every time I start up etc. I should really get it looked at but I just kinda got used to it.
- DinosaurEyes
Oh and I don't think there's a way to code it away.
I have now successfully coded out EDC, very simple eventually and would take less than 20 minutes to do once you know the steps to take.
Much cleaner way to do it than any edc delete kit as there are no errors and a saving of approximately 20 Watts of power when driving. I will post a "how to" in the next few days.
- DinosaurEyes
Please do!keving1 wrote: ↑Thu Sep 28, 2017 7:26 pmI have now successfully coded out EDC, very simple eventually and would take less than 20 minutes to do once you know the steps to take.
A "How-to" has now been posted at viewtopic.php?f=46&t=101129DinosaurEyes wrote: ↑Fri Sep 29, 2017 12:15 amPlease do!keving1 wrote: ↑Thu Sep 28, 2017 7:26 pmI have now successfully coded out EDC, very simple eventually and would take less than 20 minutes to do once you know the steps to take.
- Twin Turbo
How you finding the ride on coilovers compared to active suspension?
