So i just found out I can open the roof from the key! Any other tricks I should know?
- sunnydays
Hey all,
I just found out I can open the roof by holding the unlock button! Yay. I thought this was comfort access only, or you had to buy a smart top module?
I have 2 questions really,
How can I close the roof from the fob?
Any other cool tricks I should be aware of?
Thanks guys!
Thanks guys!
- Marlon
Yeah, it took me 6 months to find that out - good for posing
You can't close it with the fob for 'safety' reasons, but you can have the fob coded to do it.
No doubt someone will be along with more details.
Gone: 3.0si 2008 E85
911 997 Carrera S
- markplant
You can put key in door an hold in lock position at it should close roof
To lock from remote , get a smart top,
If you press unlock twice, then open drivers door the window should drop to allow easier access indoor can't be opened fully, close door window should go back up
- Marlon
Here another thread with more info. seems that a 'gaptech module' will give you extra functionality:
viewtopic.php?t=38063
911 997 Carrera S
gaptech is e85 only, I wish they made one for the e89, the smarttop does the same thing but costs three times as much
- afennell
Is this a feature for all z4s?
Onlineobewan
Every day is a learning daymarkplant wrote: If you press unlock twice, then open drivers door the window should drop to allow easier access indoor can't be opened fully, close door window should go back up
E89 2.0 SDrive MSport
Honda CB500F.
Gone but not forgotten E85 2.0 MSport
Honda CB500F.
- Zed Five
Comfort access allows roof closure. E89 only.
Why is it that people who can't take advice always insist on giving it?
E89 35is | BMW S1000rr Motorsport Ed.
- Smartbear
I thought that was disabled by bmw due to safety concerns?Zed Five wrote:Comfort access allows roof closure. E89 only.
e85 3.0si sold
All standard E89s can lower the roof using the key fob. You obviously need to ensure the boot tray is locked, and when pressing the button you need to make sure you don't let go as this will halt the process. It takes a while to start, to the point where I kept giving in when I first got mine as I assumed it wasn't working.afennell wrote:Is this a feature for all z4s?
I'm not sure if it's a safety reason or a make money through extras reason, but cars with comfort access gain the ability to close the roof through the key fob as well.Smartbear wrote:I thought that was disabled by bmw due to safety concerns?
Obviously non-standard cars that have a smart top or some other addition may have opening/closing from the fob enabled or even disabled.
I have no smart top and opening from the fob is a feature I really like. When leaving work I can unlock and lower the roof whilst walking across the car park... when I get there the roof is down, stowed away and ready to go.
As for other fancy features, OP, I like the Google maps send to car feature. Find your destination on maps and send it straight to your iDrive sat Nav. Start car, open message, start navigation.
- Yorkie Z
Unfortunately it doesn't work on the E86
A Dirty M///
Pop key in ignition and start.
Stop.
Remove key, press start and it starts up no key.
Stop.
Really? Is that on all Z4s?flybobbie wrote:Pop key in ignition and start.
Stop.
10-plate E89 35i, Deep Sea Blue
67-plate F15 X5 35d, Space Grey
- Zed Five
Then leave the key at home. Drive somewhere, turn off engine and you're screwed.flybobbie wrote:Pop key in ignition and start.
Stop.
Very handy in the winter as you can start the car and then lock it back up again and go back inside to drink your coffee.flybobbie wrote:Pop key in ignition and start.
Stop.
Obviously keeping a weary eye on the car at all times.
