ronk wrote:What do our friends across the Atlantic say?
" No substitute for Cubic Inches"
Don't get them involved, they think you need a v8 to get the shopping
Well looks like I am eating humble pie - I would have put money on that - as I did some reasurch while ago - good callSmartbear wrote:You're wrong, no difference between the engines & the injectors are identicalTwin Turbo wrote:Correct - there are some minor differences between the engine range.ronk wrote:
Im sure i read on here that the injectors are different?
However the question is - is it under warranty and how far you want to go?
If its under warranty then I would recommend RaceChips; if you want to keep only to stage 1 - as they provide a engine warranty
JB4 - is great if you want to go to stage 2 (remove cats), or go for Meth injection - however you need to tap into the canbus
If car is not under warranty; then a tune from evolve is kool
Real oem for 18i
https://www.realoem.com/bmw/enUS/showpa ... Id=13_1416
Real oem for 28i
There is no difference between the engines (or turbos)
No replacement for displacement.ronk wrote:What do our friends across the Atlantic say?
Where did you get the figure of 11:1 from? 90% of hits on google show 10.3:1 for the 28i.warmasice wrote:My understanding is this:
20i runs at 0.55 bar of boost. Compression ratio of 10:1
28i runs at 1.15 bar of boost. Compression ratio of 11:1
Structurally, the difference between these engines is only in the form of pistons. For engines with a compression ratio of 11:1 (28i), there is a smaller volume of piston recess in the piston crown. 20i models can be remapped or have a piggy-back box added to increase the boost. However, the compression ratio can't be altered. Hence, 28i models can be remapped to a higher bhp.
That's incorrect, all uk n20 engines have the same compression ratio, in the USA market some n20 engines have higher compression in the f30 range of cars I believe.warmasice wrote:My understanding is this:
It seems amazing to me that punters were conned in to stumping up and extra £8k for mapping and marginally bigger brakes. Brillient marketing if true and food for thought when considering a daily driver from the elewhere in the BMW rangeTwin Turbo wrote:So what your saying replace the DMU and you make an 18i to an 28i?
So how come no one has reported of doing this? (As I am aware)
I thought it had warp drive or was that the 35is...warmasice wrote:You're all wrong. The 28i has a flux capacitor!
Haha!!Pastry wrote:I thought it had warp drive or was that the 35is...warmasice wrote:You're all wrong. The 28i has a flux capacitor!
I doubt that the power of the DME module has anything to do with it. It will purely be the code that runs in the module that differs.Smartbear wrote:The reason the 28i can be mapped higher is because it has a more powerful dme module.
It's already possible to get the 18i remapped to a higher output than the standard 28i.R.E92 wrote:I doubt that the power of the DME module has anything to do with it. It will purely be the code that runs in the module that differs.Smartbear wrote:The reason the 28i can be mapped higher is because it has a more powerful dme module.
It's not as simple as just replacing the DME with one coded for a 28i as BMW have put measures in place to prevent that. I'm sure there is a method to circumvent this but beyond the reach of most people.
The best bet is for someone to reverse engineer the DME code like people have done with the N54 in the 35i and 35is. The N20 engine seems like a perfect candidate for the likes of Martial at MHD. If the N20 becomes popular for tuners then I'm sure it will happen.
I don't see why people get so upset about getting a de-tuned engine. You guys should be happy, you have an engine which will probably never go wrong since it's only running at 70% of its rated output.
Also there is the possibility that someone puts to effort into cracking the N20 DME and you guys have yourself a hugely discounted 28i.
Processing power has nothing to do with it. The processing requirements of an engine do not increase as the power output increases. The DME is just telling the plugs when to spark and how long the injectors should stay open when spraying fuel, no additional calculation is needed for the higher power output of the 28i.Smartbear wrote:It's already possible to get the 18i remapped to a higher output than the standard 28i.R.E92 wrote:I doubt that the power of the DME module has anything to do with it. It will purely be the code that runs in the module that differs.Smartbear wrote:The reason the 28i can be mapped higher is because it has a more powerful dme module.
I think the difference between the dme's is in the processing power, the light weight version probably can't support such sophisticated mapping & falls a little short because of this? (Just guesswork on my behalf)
