Your experience / recommendation on Geometry set up.
Busterboo
Post by Busterboo » Mon Mar 13, 2017 3:53 am
john-e89 wrote:
Busterboo wrote:
john-e89 wrote: Anyway cut to the chase. The general consensus, on this forum anyway, is that 19" E89 OEM wheels can crack and it's because of run flats in most people's opinion, which I think you know. It's also opinion that non run flats serve 2 purposes; To help prevent cracking and, and I can varify this, give a much better ride. I don't think you are without common sense and it's not rocket science to agree with the above based on common sense. You seem to have been round the houses wanting proof of this that and the other when there is none. So if you want 19's, don't deny yourself, fit them with non run flats, stop fretting about it, and enjoy your car. :thumbsup:
I'll cut to the chase, too, then.
How do RFTs crack wheels?
Vidi, vici, veni
Online
Nictrix
Post by Nictrix » Mon Mar 13, 2017 8:42 am
Busterboo wrote:
You really are obsessed with tyres, runflats and cracked wheels arnt you :lol:
john-e89
Post by john-e89 » Mon Mar 13, 2017 9:30 am
Busterboo wrote:
:? No idea, who said they do? I've never heard of it. Think you've maybe been spending too much time on'tinernet reading scare stories. Why not go and ride a bike or something instead.
Don't fall off will you.....
MR2 MK 2
E89 35is
G29
Busterboo
Post by Busterboo » Mon Mar 13, 2017 10:36 am
No, I was replying to john-e89's post. I don't have the 19" wheels that crack or RFTs.
Vidi, vici, veni
Busterboo
So, you can't answer the question, then? :D
Vidi, vici, veni
dario
Post by dario » Mon Mar 13, 2017 10:53 am
Guys, you know who you are.... can you take your man love to a dedicated thread for man love specifically please as this helps me not one jot. Thanks.
Busterboo
Post by Busterboo » Mon Mar 13, 2017 10:56 am
dario wrote:
Twin Turbo wrote:Going from memory - but need to re-check my settings
Front Camber -0.5
Front Toe 0.05ard set
Rear Camber -2.5
Rear Toe 0
Out of interest, Do you know the standard numbers?
Didn't this help? :(
Postby Busterboo » Mon Mar 13, 2017 3:48 am
The Hunter standard Rear Camber for the E89 with Adaptive M Suspension on 18" wheels is 2 degrees 20', with 10' Toe
Vidi, vici, veni
dario
Post by dario » Mon Mar 13, 2017 11:26 am
Busterboo wrote:
Front Camber -0.5
Rear Camber -2.5
Rear Toe 0
Yes it was helpful, but the ancillary stuff doesn't :thumbsup:
Busterboo
Post by Busterboo » Mon Mar 13, 2017 12:07 pm
Fair enough.
Returning to camber ... Let me state the obvious. The inner edge damage in your video is consistent on both rear wheels. This indicates a common cause - or causes - on both wheels, of course. As you know, the usual suspects in such wear are camber settings and tyre pressures, or a combination of them.
So, since you've reported similar wear on your previous/other BMWs, are the common factors the settings & pressures you use?
Vidi, vici, veni
dario
Post by dario » Mon Mar 13, 2017 12:49 pm
Busterboo wrote:
Fair enough.
I don't know off hand, but both Z4 and GT will be as posted on the door shut of either cars.
