Speakers
cmp999
Speakers
Post by cmp999 » Thu Apr 27, 2017 9:33 am
Hi, I have been searching the forums and have not found the answer yet. I have a 2011 e89 Z4 with the Professional radio (no nav) with the 6 speaker system. When fading to the rear shoulder speakers the sound is terrible, has anyone tried changing these speakers, if so, what with and is it easy to do?
Thanks in advance :thumbsup:
Smartbear
Speakers
Post by Smartbear » Thu Apr 27, 2017 10:25 am
cmp999 wrote: Thu Apr 27, 2017 9:33 am Hi, I have been searching the forums and have not found the answer yet. I have a 2011 e89 Z4 with the Professional radio (no nav) with the 6 speaker system. When fading to the rear shoulder speakers the sound is terrible, has anyone tried changing these speakers, if so, what with and is it easy to do?
Hi if you use the search facility it brings up info on this, here's just one thread-
viewtopic.php?f=23&t=90298&p=1331312&hi ... e#p1331312
e85 3.0si sold
cmp999
Speakers
Post by cmp999 » Thu Apr 27, 2017 11:10 am
Thanks for that Smartbear, I have used the search facility. I'm just asking a specific question about those speakers, as much as I like my music I do not want to go to the extent or expense of upgrading the whole system.
Maniac
Speakers
Post by Maniac » Thu Apr 27, 2017 11:38 am
While the speakers are cheap, the issue is not entirely their fault, there is a crossover built into the head unit that sends a different signal to these speakers. To upgrade the sound, you'd need to add a new AMP and Speakers and take a direct line out from the head unit (or get a new head unit).
benv6
Speakers
Post by benv6 » Thu Apr 27, 2017 12:56 pm
I have tried it :) ...
Changing the shoulders speakers (mids) alone, won't make any difference even if you go for top of the range speakers.
As mentioned before, you will need to deal with the signal and the only way to do it without changing the HU is to add an AMP, a DSP one preferably and in this case you might as well change the other speakers.
If I was you, instead of changing the shoulder speakers, I would add some decent tweeters - they will make some difference to your sound quality :wink:
Hope this helps.
Now: BMW 335D Touring
Previous: 435D Coupe, BMW Z4 E89 35i, BMW Z4 E85 2.0, BMW E46 330CI
cmp999
Speakers
Post by cmp999 » Thu Apr 27, 2017 9:43 pm
Thanks for that guy's, Cheers, :thumbsup:
