Rear Light Facelift Update Cheap How to
ThreeOZ
Re: Rear Light Facelift Update Cheap How to
Post by ThreeOZ » Thu Sep 15, 2011 10:09 pm
51717167525 Frame, rear light, left
51717167526 Frame, rear light, right
When you mention the plastic boot panel I assume you refer to the center bumper mount.
51127158875 Mount, bumper, center
komec
Post by komec » Fri Sep 16, 2011 2:42 pm
Allright.
Thanks mate :thumbsup:
ThreeOZ
Post by ThreeOZ » Sun Sep 18, 2011 1:23 am
This is not working for me. I swapped the pins as specified. I validated the pin swaps in the BMW manual. The right side is woring fine, the left side is all screwed up. Left turn signal flashes the left upper LED at a very rapid rate. It should be flashing the amber. Something is wrong.
komec
Post by komec » Sun Sep 18, 2011 7:57 pm
Hmm thats weird .. On Nahodos blog its told to do this way:
http://translate.google.fi/translate?s ... 19777.html
left side
old cluster
6 green
5 Brown
4 blue
3 gray
2 yellow
1 empty
New cluster
6 blue
5 gray
4 green
3 brewing
2 empty
1 yellow
right side
old cluster
6 empty
5 blue yellow
4 yellow gray
3 brown blue
2 brown
1 blue black
new cluster
6 empty
5 brown blue
4 Brown
3 blue-black
2 yellow-gray
1 brown
komec
Post by komec » Mon Sep 19, 2011 8:01 pm
The bumper that i bought from ebay, arrived today. After several hours of polishing, it didnt even need re-spray :-D
Tail lights should arrive later on this week, so I should be able to begin installing at next weekend..
Lets hope they work on my car :-o
komec
Post by komec » Thu Sep 22, 2011 5:20 pm
lights arrived today.
I gave them a go, and everything worked great after coding (HUGE thanks to nahodo) :thumbsup:
Correct wiring clusters for me was
Left side
1 Black-yellow
2 empty
3 brown
4 black-green
5 gray-purple
6 blue-green
Right side
1 blue-brown
2 gray-yellow
3 blue-black
4 brown
5 blue-yellow
6 empty
I will post some pics after i have installed everything at saturday.
komec
Post by komec » Sat Sep 24, 2011 2:57 pm
Allright.
I got everything done. :thumbsup:
installation took about 2.5h, so it was fairly quick. Thanks to these how to guides..
I still need to get those light frames to fix that gap between the rear fender and the light.
Dice
Post by Dice » Sun Sep 25, 2011 12:31 am
komec,
looks good/näyttää hyvältä (mun mielestä paremmat ku vanhat) :thumbsup: !
Terveisin
Dice
ranski
Post by ranski » Thu Oct 13, 2011 2:35 pm
Hi guys,
Apart from the recoding and bumper - Would LHD rear lights work with a RHD car?
Z4 3.0 / Mods done... too many to mention
komec
Post by komec » Thu Oct 13, 2011 5:56 pm
I don't see any good reason why they wouldn't work..
ThreeOZ
Post by ThreeOZ » Sat Oct 15, 2011 7:05 pm
ThreeOZ wrote:This is not working for me. I swapped the pins as specified. I validated the pin swaps in the BMW manual. The right side is woring fine, the left side is all screwed up. Left turn signal flashes the left upper LED at a very rapid rate. It should be flashing the amber. Something is wrong.
I had a loose or poorly seated bulb. I removed the assembly, reseated the bulbs, problems solved.
ThreeOZ
Post by ThreeOZ » Sat Oct 15, 2011 7:19 pm
A few teaser shots before I go for paint. I've been doing all of the pre fitting work myself.
ranski
Post by ranski » Wed Nov 16, 2011 3:27 pm
Another lemming :)
After months of searching and missing out on rearfaclift lights on ebay, I managed to pickup a set for £110
They were a tad scratched and dull but i used a restorer to get them back to a near new condition
I should be getting my Ebay M rear bumper and frames back from the painters next week, but have wimped out on the rewiring and recoding, as i have found a place near Birmingham that will do it for £80 - if all goes to plan i will post some pics and details -
Bitter, sweet... This maybe my last major mod
billygilly
Post by billygilly » Wed Nov 16, 2011 5:02 pm
Ranski tell me how this goes as I haven't got the gear to code mine
JDM
Post by JDM » Wed Nov 16, 2011 5:08 pm
ThreeOZ wrote:A few teaser shots before I go for paint. I've been doing all of the pre fitting work myself.
:o
May seem a daft question but how do you open the boot? It looks from the pictures that the rear spoiler is attached to the rear wings or is it just me?
Personally I don't like the rear spoiler. I think it spoils the lines of the car... but each to there own :D
04 3.0SE Roadster, 07 3.0Si Coupe, 12 2.0iSdrive M Sport... Gone but not forgotten
Now proud owner of an Audi TT TFSI S line, Misano Red Amplified black edition... Don't shoot me.
