Electrical starter issues
- Worcester_spoon
So, battery has run flat a couple of times - I thought it was me leaving the video recorder plugged in, but I've unplugged it and still having issues.
The doors open and all the dash lights come on, but I'm just getting a click when it turns over. Could it be an alternator or starter motor issue rather than a battery issue?
03 Z4R 3.0i/Silver/custom quad/330d brake upgrade/LSD/G-Power supercharger/FIC 365cc injectors/Severn Tuning map
- markplant
Re: Electrical starter issues
Could be the solenoid sticking on the starter
- Chrissyg
I suspect you need a new battery. Give it a charge and see if the issue goes away? I had the same when I'd left my car for 4-5 weeks and came back and it was flat and made the noise you've described.
Chris
Chris
2020 Range Rover Velar D240 HSE
1988 Land Rover 90
1972 Land Rover Series 3
1988 Land Rover 90
Get a multimeter on the battery.
- Roundozo
I've got a multimeter you can use but I'm in SP5 so a little drive away. If the car isn't starting then this would be quite difficult. If I drive past Basingstoke I'll drop you a pm. Not sure if I am going that way for a few weeks though.
Past - Z4 Coupe, gone but not forgotten
Present - 530d M sport touring
- Worcester_spoon
Thanks guys. Battery was new 5 months ago and until recently I've not had an issue. I was driving it 3 or 4 times a week and it's only when this has slowed down there is an issue. Trip to an auto electiprician is probably called for u reckon.
Do the first few steps yourself. Check the battery output, 12.35 V when disconnected (and having been left for a few hours) is approx. 75% and anything lower than that I would change. Check the voltage with the engine running - the alternator should be putting out 13.2–14.4 V.
- sk93
check for a parasitic drain on it too.. I was having very similar issues, and turned out to be the sh***y connector in the central cubby hole (the connector that detects the door being open or closed).
I removed this, and my car can now last at least a week without being started.
beforehand.. it was a couple of days at best.
However, if you've emptied the battery properly a few times, then tried to start a few times whilst it's drained, its not likely to have done it any good.
most places offer a free battery test (using a "deep cycle" tester I think it's called? whatever.. it's more than a multimetre) and this will tell you if your battery is kaput.
good news is, if it's only a few months old, and you have the receipt, you'll get a free replacement for it
- Worcester_spoon
Thanks guys - I retro fitted a USB socket where the cig lighter was and I suspect this may be the issue (as it has a small blue light on it). Going to swap this back at the weekend and see if it solves the issue. Didn't have a problem before this, albeit under different conditions (I.e it was being driven more).
- sk93
I've got a usb converter and an arduino permenantly powered in mine at the moment.. these don't draw that much that it would kill a battery that quick (unless they're borked maybe?)Worcester_spoon wrote:Thanks guys - I retro fitted a USB socket where the cig lighter was and I suspect this may be the issue (as it has a small blue light on it). Going to swap this back at the weekend and see if it solves the issue. Didn't have a problem before this, albeit under different conditions (I.e it was being driven more).
- Worcester_spoon
Ok, so put a multimeter on it - drawing around 2.5 when car open, drops to around 1.8 when car locked for 30 seconds whilst systems shut down and then it's at 0.03.
Battery is going flat inside 6 hours...
Makes no sense, so not sure what to do now. I have a faulty actuator in the n/s door, so wondered if that could be causing an issue?
Next up is pulling fuses I guess, but given its only pulling 0.03, not really sure what I'm going to be able to find.
Damn bloody stupid car.
- fixit man
0.3 Amps should not make a battery flat from fully charged in 6 hours, I'd get your battery tested regardless of it only being 5 months old , it could be faulty
- Number5
I've had a similar problem but definitely diagnosed mine as a Starter Motor Issue. Somethines I have nothing at all, just a click, then other time loads of juice to turn it over and raise/lower the roof, so not a power/charge issue I dont think.
Also tapping the starter/solenoid with a spanner seems to work sometimes and it turns over and starts OK.
So...
a) Where is the best place to source a Starter Motor for a 3.4 Alpina ( Inc any exchange deals for the old unit?)
b) is it a standard 3.0 Starter as on the car when BMW sent it to Alpina ?
All advice appreciated
So...
Alpina Roadster #307
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
10x E85 Se/Si Roadsters
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Double check your alternator voltage when it's running at idle and then load it up with consumables on and see if the voltage drops dramatically. Battery might not being getting charged when your driving it.
- Worcester_spoon
Thanks bowser - I'll give it a go.
