trying to replace high beam bulb
Truman
Post by Truman » Sat Sep 23, 2017 6:43 pm
Evening all,as the thread title says I'm trying to change the off side high beam bulb..managed to get all the covers off and twisted the holder as per the owner's manual..the bulb came out still connected to it.Replaced the bulb in the holder, but can't get it all to fix back into the h/l unit I've attached a couple of (bad) photos..can anyone see if there's anything missing from either the holder or the lamp assy.? I've tried to put the bulb in first and attach the holder but there appears to be nothing locating either item to the h/l assy. itself..
TIA.. :)
Rusky
Post by Rusky » Sun Sep 24, 2017 8:51 pm
took me a good 45mins to get the near side little barstool in on mine, in the end i walked away had a coffee then went back to it and it went straight in. :oops: :oops:
3.0l Silver SMG, whippy and ginge fringe/ Sound gen mod/ Media bridge fitted (bluetooth and audio streaming) / Clear third break light/ Hard Top/ Eibachs springs and DLV back box/ Roof motor in the boot/ plus lots more.
Ducklakeview
Post by Ducklakeview » Sun Sep 24, 2017 9:08 pm
You've probably got either the bulb in the wrong way round, which prevents the clip from going back in (deliberately) or the clip itself upside down?
Mike
NickDE
Post by NickDE » Sun Sep 24, 2017 10:21 pm
On mine both sides were a pig to get back in. I ended up jacking up the car and taking the front wheels off so that I could get into the wheelarch and have a clear view of what I was doing. Then they went in OK.
Darkness gone, go Darknes2, go Frozen, go Tronic
Ducklakeview
Post by Ducklakeview » Sun Sep 24, 2017 10:53 pm
When putting the holder back in, the lugs need to be in the "10 to 2" position and not "20 to 4" if that makes sense..
Mike
Truman
Post by Truman » Mon Sep 25, 2017 10:15 am
Ducklakeview wrote: Sun Sep 24, 2017 10:53 pm When putting the holder back in, the lugs need to be in the "10 to 2" position and not "20 to 4" if that makes sense..
Mike
Thanks for all the replies...which lugs are you talking about Mike? The only ones I can see on the holder are 180 degrees from each other ie quarter to and quarter past or on the hour or half past .. I wondered if anything was missing from either the holder or the lamp unit..I must be having a particularly dumb weekend :)
Buckz
Post by Buckz » Mon Sep 25, 2017 10:20 am
Have you loosened those two torqxs bits? By 3 turns on so then you stick the bulb in rotated a little and rotate the other direction to clip in behind the torqxs heads and then tighten them back up a little.
Truman
Post by Truman » Mon Sep 25, 2017 10:57 am
Buckz wrote: Mon Sep 25, 2017 10:20 am Have you loosened those two torqxs bits? By 3 turns on so then you stick the bulb in rotated a little and rotate the other direction to clip in behind the torqxs heads and then tighten them back up a little.
Nope,not touched those....I'll have a look this evening when I get home...
Ducklakeview
Post by Ducklakeview » Mon Sep 25, 2017 11:20 am
The lugs on the holder itself are offset slightly. You don't need to loosen the torx screws, they can and do snap the plastic posts away from the headlight as they become brittle with age and heat.
Mike
Truman
Post by Truman » Mon Sep 25, 2017 12:33 pm
Ducklakeview wrote: Mon Sep 25, 2017 11:20 am The lugs on the holder itself are offset slightly. You don't need to loosen the torx screws, they can and do snap the plastic posts away from the headlight as they become brittle with age and heat.
Mike
Sorry to be a bore Mike,but can you tell from my photo if the these posts have been snapped on mine? Maybe that's why I can't fit the bulb back in..
MD99
Post by MD99 » Tue Sep 26, 2017 8:36 pm
I had this issue too and thought something missing. The low beam bulb holders are different and slide under lugs not torx screws.
I found that the bulb would only locate on one or other torx screw. Fixed this by putting an electrical ring terminal on one of the torx screws and this has the effect of giving the bulb holder more surface area to grip.Loosen the other screw one 1/2 turn too. All this is easier with the wheel off.
If like me you only have a standard trolley jack and its too high to go under the car , drive on to some wood off cuts ( like hard decking) to lift the car an inch before jacking up.
markalp
Post by markalp » Wed Sep 27, 2017 1:19 am
Truman wrote: Sat Sep 23, 2017 6:43 pm Evening all,as the thread title says I'm trying to change the off side high beam bulb..managed to get all the covers off and twisted the holder as per the owner's manual..the bulb came out still connected to it.Replaced the bulb in the holder, but can't get it all to fix back into the h/l unit I've attached a couple of (bad) photos..can anyone see if there's anything missing from either the holder or the lamp assy.? I've tried to put the bulb in first and attach the holder but there appears to be nothing locating either item to the h/l assy. itself..20170923_181349.jpg20170923_181341.jpg TIA.. :)
This is why I get Halfords or the garage to do mine. (Some people say it is lazyness, but I just think it is because I'm special) :)
Alpina Roadster S LUX #030
Truman
Post by Truman » Wed Sep 27, 2017 6:41 pm
Got it sorted..after checking the n/s holder for comparison I realised that I'd managed to bend one of the lugs on the bulb holder and it wouldn't locate correctly..5 mins straightening out and it's all back together complete with covers etc...thanks to everyone who tried to help out... :)
