ALARM PROBLEM
ALARM PROBLEM
Hello All,
After lurking on here for a while reading up all there is about the z4 I have finally bought a lovely black, 2005 3.0i litre, with just 18,000 miles. I am absolutely loving it!
The only problem I have at the moment is that the alarm, when set through the key fob, goes off for no apparent reason. This can either be 20 seconds, a few minutes or several hours after the alarm is set. When I lock the car manually the alarm seems to be fine (although I'm not sure if this activates the alarm?).
I only bought it off the independent dealer a few weeks back but I'm pretty sure this wont be covered under the standard 3 month dealer warranty.
I'm reluctant to take it to a BMW dealership just yet as it may be an easy fix and it's one of those problems that when I take it to the dealer the alarm probably won't go off, they will charge me 2 hours labour and when I get it home the alarm will go off again!
Any advice hugely appreciated.
C.
C.
- WLH
Re: ALARM PROBLEM
maverick25, welcome to the forum...
I have no idea what the cause of your problem is...
I have the BMW dealer installed alarm system and when I lock using the key the alarm is not active.
- gannet
Re: ALARM PROBLEM
bonnet sensor is common failing...
-- Gannet.
Current: MINI JCW... - Modification: Driver Upgraded
Previous: DS3 DSport, Z4 3.0SE, 206 GTi & XS, Alfa 147 Lusso
Re: ALARM PROBLEM
....where is the bonnet sensor? Will it need replacing and is it something I could do?
- Zedster
Re: ALARM PROBLEM
As Gannet has already said and there are a number of threads on here indicating to a possible Bonnect Sensor fault.
i would take the car back to the Dealer and complain that the fault was on the car when you bought it. Get them to fix.
SI Coupe Silver Grey
- RustyZ4
Re: ALARM PROBLEM
x2Zedster wrote:As Gannet has already said and there are a number of threads on here indicating to a possible Bonnect Sensor fault.
Hi & Welcome btw
Z4 E85 3.0, gone but now with son
Re: ALARM PROBLEM
My wife's car suffered a similar problem; the alarm would trigger at random intervals after setting. Locking the car manually does not set the alarm, so was an acceptable short term solution.
It was the bonnet closed sensor; about £10 from BMW and a complete doddle to fit.
G29 S30i in SFR - my wife's car and her third Z
BMW M2C - gone, replaced with an i4, but its only use is shopping, the Z is our main touring vehicle
Long gone, but not forgotten - 1988 E30 M3
Re: ALARM PROBLEM
Brilliant! Thanks chaps, I will give it a go.
Re: ALARM PROBLEM
Hello folks,
I had the same problem with my alarm, Googled it, found this forum, and promptly bought the bonnet switch, for £8. It solved the problem. Given that the BMW dealer had a few of these switches in stock, I guess it is a common problem!Thanks for the advice.
- IvanDobskey
Re: ALARM PROBLEM
I seem to have this problem with mine! Alarm keeps going off. Anyone know where abouts the bonnet sensor is? I'll give it a go changing it.
2.5i Roadster Maldives blue with 108's and a stubby
- easty027
Re: ALARM PROBLEM
as above, i bought a bonnet sensor for £8 from my local bmw stealership and swapped it over in a matter of seconds. And im no specialist !
- IvanDobskey
Re: ALARM PROBLEM
Is it obvious where under the bonnet it is? I've only just bought the car and I've got both the wiper and alarm problems. Very annoying!
- gannet
Re: ALARM PROBLEM
it is under the windscreen in the middle - where the two diagonal strut braces meet at the centre of the car
pretty obvious when in front of you
-- Gannet.
- IvanDobskey
Re: ALARM PROBLEM
Ah ok, cheers! I've got a few bits and pieces I want to pick up from my local BMW dealer anyway so I'll add a bonnet sensor to the list.
- chris
Re: ALARM PROBLEM
Mine had this too, took about 30 seconds to fit
Stupid putting it right above the engine, all the heats going to kill it!
