I also want to deactivate my headlight washers as they serve no purpose whatsoever in our climate and I do not wish to lose the little covers that seem to fly off at the first opportunity. Looked in the manual but found no information. Then looked at the fuses behind the glovebox and found a little cardboard diagram, showing that fuses 13 (5A), 38 (30A) and 40 (30A) have something to do with wipers, windscreen washer and headlight washer - in no particular order. First removed fuse 13, but the headlight washer still worked (funny, the volume control on the steering seemed to be deactivated though). Then pulled fuse 40, but have not had the time to test if the headlight washer is now deactivated - the windscreen washer and wipers still work, so maybe this time lucky. Getting those fuses out is a real PITA, even with the little plastic tool.Leon. wrote:Sorry to hear about this, what a PITA!
Great idea! Where can I find this fuse?a11y wrote:Not that this helps you in getting another one, but it might help it stopping happening again...
I've deactivated my headlamp washers by removing the appropriate fuse as I was worried about the cover coming loose - it was a known issue with a previous car I owned (Renault Clio with xenons). I found them a waste of time, soaking the entire front end of the car with minimal effect of actually cleaning the headlamp lens, plus I rarely let the car get that dirty anyway. I realise they're required legally for MOT on xenon-equipped cars (I'm running halogens ) but it's easy to reinstall the fuse for the likes of MOTs. As I say, might be an option once you've fitted a replacement.
Headlight washer cover fell off :(
- Siener2
Re: Headlight washer cover fell off :(
E86 Z4MC; E36 323i now gone; E46 330i; E60 530d. And a Volkswagen for vacations.
All driven weekly, or should that be weakly...
Cool, keep us posted
- cj10jeeper
Why not just pull the power plug off the headlanp washer motor near the warer reservoir?
Could be the answercj10jeeper wrote:Why not just pull the power plug off the headlanp washer motor near the warer reservoir?
- Siener2
So I can confirm that it is definitely fuse 40 (30A) that you need to remove to deactivate the headlight washer. I have tested that the wipers, windscreen washers and the rain sensor all still work.Siener2 wrote: Then pulled fuse 40, but have not had the time to test if the headlight washer is now deactivated - the windscreen washer and wipers still work, so maybe this time lucky. Getting those fuses out is a real PITA, even with the little plastic tool.
The fuses (behind the glovebox / cubby hole) are laid out in four rows, numbered from the left bottom. The bottom row has from 1 to 17, the second row from 18 to 34, the third row from 35 to 51. The top row has the big buggers from 52 to 60. In mine positions 1, 2, 3, 17, 18, 19, 34, 35, 51, 52 and 53 are empty.
- sixspeed
I lost one of mine a couple of years back, and have since disconnected the pump for the headlight washer to stop them covering my car in washer fluid when I just want to give the windscreen a quick clear!
Think it took me about 4-5 weeks to get a replacement too. Had to pay for mine though mind you, as they weren't accepted as a warranty item back then I guess!
This happened on mine. They could easily worm out of it by saying it had been stolen, but because my local dealer know me, they replaced it 2 days later, fully painted and fitted, under warranty.
How do you disconnect it Sixspeed? I hate them! (Messes with my car OCD putting water over the front of the car!)
Currently car-less!
Previous: Z4 3.0si Coupe & Z4M Roadster
Plus a few others!
Plus a few others!
This is quite an old thread, apologies for the bump, but I suffered this problem over a year ago and when I found out how much it was going to cost me I wasn't exactly enamored with the situation, which is why it took me a year to fix. The vertical bracket on my pump head had snapped at some point and my cap/connector gone with it. Irritatingly the most expensive single part, the pump, worked fine so I figured maybe I could repair it. I ordered all of the parts (great service by the parts dept. in Lincoln) and measured up the key ones once they arrived, drew them up and used Shapeways to print them at a cost of around £10. I did think about printing the actual cap too, but it's complex, asymmetric and you've got to get it primed/printed (great service from Elite Motors in Northampton on my new one).
Parts. I didn't bevel any of the printed parts because I knew I could file them if I wished later.
Before. You can see the vertical support has snapped, leaving my cap stranded somewhere in the countryside.
Prepared. I've filed off the remainder of the old bracket and taken advantage of the larger surface area to glue onto.
After. Some heavy duty epoxy and it's all set. Although there is a small snag...
..so, I did all of the above after fitting my new parts, which means the fix is untested. I think this is a pretty solid job and I wouldn't be afraid of using it in my car, which if either one fails again I will do. I'm not selling the parts yet but you can see them on Shapeways https://www.shapeways.com/designer/gord. If there is demand I'll happily make them available, there will be no mark-up, you'll just pay the cost of the materials. Or there may be no demand, in which case I have learnt quite a bit about the power of printing parts.
- gannet
fantastic if it works
-- Gannet.
Current: MINI JCW... - Modification: Driver Upgraded
Previous: DS3 DSport, Z4 3.0SE, 206 GTi & XS, Alfa 147 Lusso
gord wrote:This is quite an old thread, apologies for the bump, but I suffered this problem over a year ago and when I found out how much it was going to cost me I wasn't exactly enamored with the situation, which is why it took me a year to fix. The vertical bracket on my pump head had snapped at some point and my cap/connector gone with it. Irritatingly the most expensive single part, the pump, worked fine so I figured maybe I could repair it. I ordered all of the parts (great service by the parts dept. in Lincoln) and measured up the key ones once they arrived, drew them up and used Shapeways to print them at a cost of around £10. I did think about printing the actual cap too, but it's complex, asymmetric and you've got to get it primed/printed (great service from Elite Motors in Northampton on my new one).
I need to find where i can get one of these triangular looking things, as its the part i am missing
