I haven't managed to get it off yet to investigate as my Little Helper is swanning around in warmer climes til next week, but my hardtop seems to have developed a bit of an odd noise....when I go over a bump theres a clonking noise from inside....just behind and slightly above the right hand securing point. With the small cover removed theres the usual Webasto label stuck on a bit of metal boxing and its about 3-4 inches behind this....you can even 'feel' the clonking if you put your hand on the roof.
Its well away from the securing point itself (which I've checked anyway) and the hardtop itself seems to be firmly affixed with no movement whatsoever, but I can't think for the life of me what might be loose behind there - its definitely internal....any ideas?
Hardtop rattle
- lacroupade
Hardtop rattle
If toast always lands jam side down, and a cat always lands on its feet, what happens when you strap a piece of toast, jam side up, to the back of a cat?
- Taz
Re: Hardtop rattle
you don't get this on the coupe
- lacroupade
Re: Hardtop rattle
You can always tell a coupe owner - they look like this when they are out of their cars....Taz x wrote:you don't get this on the coupe
