Groan from steering
fluxco
Re: Groan from steering
Post by fluxco » Sun Nov 01, 2015 12:35 pm
Hi Ducker
did you grease inside of the rubber boot or at the input shaft?
thanks
firebobby
Post by firebobby » Sun Nov 01, 2015 8:36 pm
I met up with Andy C at a car meet at the Beaconsfield services and noticed my steering had started to groan while driving around the car park, a quick look on here and then a quick spray of grease on the steering column bushes and now all quite again . :D
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
fluxco
Post by fluxco » Wed Nov 04, 2015 9:31 am
:thumbsup:
oz-boz
Post by oz-boz » Mon Nov 23, 2015 4:38 am
I had the same problem in the summer and it turned out to be the top mounts too :thumbsup:
z4all
Post by z4all » Thu Dec 31, 2015 5:23 pm
firebobby wrote:I met up with Andy C at a car meet at the Beaconsfield services and noticed my steering had started to groan while driving around the car park, a quick look on here and then a quick spray of grease on the steering column bushes and now all quite again . :D
How do you access this area?
firebobby
Post by firebobby » Thu Dec 31, 2015 5:37 pm
There's a thread somewhere on here that gives more details, but if you pop the bonnet and look down at the steering column, you should see a knuckle joint low down, just spray grease or another type of fluid into it. The knack is getting the spray up in to the joint.
Toyota MR2 NA 1995
Mini 1000 1981
z4all
Post by z4all » Thu Dec 31, 2015 6:07 pm
firebobby wrote:There's a thread somewhere on here that gives more details, but if you pop the bonnet and look down at the steering column, you should see a knuckle joint low down, just spray grease or another type of fluid into it. The knack is getting the spray up in to the joint.
What does the steering column look like from there? I haven't got a clue mate. And can't find any pic online either.
firebobby
Post by firebobby » Thu Dec 31, 2015 6:17 pm
Look in the engine bay and follow where the steering wheel goes through the bulk head/dash area, your looking for a shaft that goes down the side of the engine to the steering rack. I will see if I can find the link for you. Where do you live by the way.
Toyota MR2 NA 1995
Mini 1000 1981
z4all
Post by z4all » Thu Dec 31, 2015 6:19 pm
Thanks mate will have a look tomorrow. I'm near Watford.
firebobby
Post by firebobby » Thu Dec 31, 2015 7:28 pm
Not sure if you are near any other members who may be able to show/assist you. Depending on the weather, I will be at the Ace cafe next Monday 4th Jan if you fancy a drive down.
Toyota MR2 NA 1995
Mini 1000 1981
z4all
Post by z4all » Thu Dec 31, 2015 7:50 pm
firebobby wrote:Not sure if you are near any other members who may be able to show/assist you. Depending on the weather, I will be at the Ace cafe next Monday 4th Jan if you fancy a drive down.
Will do my best! Thanks very much for your help mate and hope to see you there.
z4all
Post by z4all » Fri Jan 01, 2016 3:54 am
I think I figured it out and it's sorted! First time I've driven the car and had some level of trust in the steering lol. Still feels a bit stiff but will keep libricating over the next few days and it should hopefully sort it's self out. Defo a big improvement already though. Many thanks guys!
firebobby
Post by firebobby » Fri Jan 01, 2016 2:13 pm
z4all wrote:I think I figured it out and it's sorted! First time I've driven the car and had some level of trust in the steering lol. Still feels a bit stiff but will keep libricating over the next few days and it should hopefully sort it's self out. Defo a big improvement already though. Many thanks guys!
That's good, so did you lubricate the joint in the engine bay.
Toyota MR2 NA 1995
Mini 1000 1981
z4all
Post by z4all » Fri Jan 01, 2016 2:20 pm
Yep. Did the one at the bottom of the middle of the engine and the one that you can see coming out from the dash for good measure.
firebobby
Post by firebobby » Fri Jan 01, 2016 2:27 pm
Well done, it's nice when you can sort things like this and your learning about your car too.
Toyota MR2 NA 1995
Mini 1000 1981
