Bulb warning light - Latest update
- Marlon
A few days ago a dashboard bulb warning light came on intermittently, and now it’s on permanently (EDIT: it actually only comes on when I indicate right - and then stays on). Also the right indicators started flashing very fast.
I realised that the front indicators have 2 bulbs in each cluster and it was the drivers side right one that was out - highlighted in white below:
So I bought a new bulb and fitted it, but I’m still getting the same warnings?
To make sure it wasn’t a faulty bulb I swapped the working bulb on the left side of the indicator cluster to the right side, but it still gives the same warnings.
As a final check I put the original ‘faulty’ bulb into the left side of the indicator cluster and it worked!
I have run a diagnostic check and there are no DTC codes.
I’ve spent all bloody afternoon on this and got nowhere
Any ideas would be much appreciated.
EDIT:
Prior to the warnings I had fitted LED side light bulbs. When I started getting the warnings I replaced the LEDs with the original standard bulbs. I read somewhere that LEDs can mess up the control module
EDIT:
Gone: 3.0si 2008 E85
911 997 Carrera S
Re: Bulb warning light - Help!
Turn off all lights , then when you first turn car on is the bulb warning light on?
Then turn on one thing at a time, and wait few secs and see when the light comes on
Thats how i normally find which circuit its on
- Number5
This is exactly what I did a few days ago and it was a rear fog light lamp.biojo wrote:Turn off all lights , then when you first turn car on is the bulb warning light on?
To clear it I had to turn off the lights and the ignition. It then only appeared when I put the fog lights on, so I would imagine its the same with yours Marlon, that you shouldnt get an error until you indicate ?
(Make sure you haven't got your headlights on auto whilst you're testing too)
Alpina Roadster #307
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
10x E85 Se/Si Roadsters
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
- Marlon
Hi fellas,
ok so I just went out and did as you suggested.
The dashboard warning blub light only comes on when I indicate right.
The right side of the indicator cluster does not flash - but as mentioned above the bulb is fine.
I'm beginning to think that the LEDs I tried (and then swapped out) have screwed up the control module.
911 997 Carrera S
- Number5
Have you tried putting in all of the original/good bulbs ( excluding the LEDs), then disconnecting the battery for a minute or so and then re-applying the juice ? May be a reset will clear it ?
If thats doesn't work, I think you'll have to just go through the procerss you just tried, but changing one bulb at a time.
I dont know if its possible that the bulb can still visibly work, but give a bad resistance reading, thus upsetting the system. However it definitely sounds as thouhg one of those right hand indicator bulbs isn't happy.
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
so one works and other doesnt?
could you have damaged the cable or connector?
- Marlon
Number5: I have replaced the LEDs with the original bulbs. I will try disconnecting the battery.
biojo: Yes thats right, one works and the other doesn't - even if I swap the bulbs, it makes no difference. So yeah, its possibly a connector issue.
911 997 Carrera S
- Number5
Possibly one of the contacts in the bulb holder at the faulty location.
These cars are weird... My recent faulty bulb was in the right hand rear fog lamp. However, although it didn't illuminate, there was a 'spare' bulb in the left hand side. I therefore pinched it and put it in the right hand side and it illuminated, yet the warning was still there.
I bought another bulb and inserted it into the left hand side. Turned lights off then on and the warning disappeared (still doesn't illuminate the Left hand side, but it seemed to want it there). It's almost as though it isn't happy unless it knows you're carrying a spare bulb on the left !
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
- Z4MO
I got my car back from Insp 2 and it has the same light on. Spoke to indy and he says the holder needs renewing as I'd asked for new bulbs in the front indicators.
2006 Black / Black Z4M Roadster
never had mine out, but can you swap the whole plug and see if it moves
https://www.ecstuning.com/b-genuine-bmw ... 127158748/
this might sound daft, but if u put hazzards on does it work
- Marlon
I did that this afternoon - I swapped both plugs and the problem is still on the right side only. its looking like a bad connection in the housing.biojo wrote:never had mine out, but can you swap the whole plug and see if it moves
I just tried the hazards and the bulb warning light does not come on and the hazards flash at normal speed. However, the right side of the inticator light still doesn't flash.
911 997 Carrera S
- Marlon
Yeah - Number5 & Z4MO - It's looking to me like a bad contact in the bulb holder
911 997 Carrera S
- Confused®
Try Cleaning the terminals with wire wool, see if its a connection problem.
- Marlon
I can't get to them - its one of those ridiculous bulb sockets that are virtually inaccessible, I'm having to work blind using a long screwdriver just to get the bulb in and out.Confused® wrote:Try Cleaning the terminals with wire wool, see if its a connection problem.
911 997 Carrera S
Sounds like bumper off and headlamp out mate. Not sure if you can get connectors singly but the wire ends should just clip in.
