Airbag light on - Have you been affected? (UK)
Captainken
Re: Airbag light on - Have you been affected? (UK)
Post by Captainken » Tue Feb 04, 2014 3:47 pm
CaptainKen
2003 3.0
Airbag light on after removing/replacing seats can't reset it
All was perfect before removing seats
2003 Z4 3.0i Auto Maldives Blue with Ivory Leather, Stubby, Angel eyes, chrome grills, zunsport lower mesh grill, M style pedals, drilled disc
mac27040
Post by mac27040 » Tue Feb 04, 2014 3:56 pm
Captainken wrote:CaptainKen
2003 3.0
How have you tried to reset it, normally you need INPA or DIS software to clear code
Sent from my iPhone 5 using Tapatalk pro
3.0i SMG Supercharged,19" CSL, AvinUSA android 10.25” screen,DSP,M6 gearknob,Coilovers,Aero F-bumper,M r-bumper,Aero skirts,Facelift front & rear lights,M sports seats,Carbon Steering wheel,Intravee,Rervese cam,Hydrographics
P4XLL
Post by P4XLL » Mon Mar 10, 2014 6:55 pm
Hi, my Z4 is the 2004 model, and has the airbag light problem.
It has not as of yet been resolved, took the car to a garage and they cannot solve this issue on their diagnostic machine.
mac27040
Post by mac27040 » Mon Mar 10, 2014 10:55 pm
P4xll
Do you know what may have caused the light, normally you will need BMW DIS software or INPA to clear the light unless there's a problem. Both will tell you what the problem is.
P4XLL
Post by P4XLL » Tue Mar 11, 2014 10:30 am
I've taken it to a garage and they connected it to their computer, they could not pick up a fault or clear the light..
So unsure whether this is the cars fault of the computers software not doing its job properly?
Perhaps I should try taking it to a few more garages?
ryanwhite19
Post by ryanwhite19 » Tue Mar 18, 2014 5:35 pm
More than likely they dont have the correct software to diagnose the code
Captainken
Post by Captainken » Thu Mar 20, 2014 11:24 pm
After trying four 'Technicians' with their different diagnostic machines which all showed 'No fault shown' despite my SRS light being on for the past two months
I finally found a guy with a 'Snap on Diagnostic machine' who also had 'No fault shown' who persevered until he found a fault which said ' Faulty seat belt tensioner on REAR near side seat' despite Z4's not having any rear seats, he reset it and lo and behold my light has now gone out and works perfectly
It's hard to have any faith in BMW electrics
andysat
Post by andysat » Fri Mar 21, 2014 5:57 pm
2006 2.0 diagnosed as the slip ring.
Gone but not forgotten.
New ride silver e93.
markeg
Post by markeg » Fri Mar 21, 2014 9:20 pm
andysat wrote:2006 2.0 diagnosed as the slip ring.
Had the same Andy. Easy DIY job to replace the slipring and then reset the light with iNPA.
previous: Alpina Roadster S, #108: gone
current: MB C-class
"veni, vidi, velcro - I came, I saw, I stuck around..."
andysat
Post by andysat » Sat Apr 05, 2014 6:57 pm
Cheers mate-took her to my indy. :roll:
Sean_Flitton
Post by Sean_Flitton » Mon Jun 23, 2014 1:27 pm
Has anyone tried an airbag light removal tool? If so how did you get on with it ?
Sent from my GT-I9505 using Tapatalk
Using Tapatalk
markeg
Post by markeg » Mon Jun 23, 2014 4:28 pm
Sean_Flitton wrote:Has anyone tried an airbag light removal tool? If so how did you get on with it ?
tried one, didn't work. INPA worked first time.
current: MB C-class
Sean_Flitton
Post by Sean_Flitton » Mon Jun 23, 2014 6:15 pm
INPA ?
Using Tapatalk
markeg
Post by markeg » Mon Jun 23, 2014 11:04 pm
Software - check eBay - allows you to do all sorts of stuff, and connects the laptop to your ODB port.
current: MB C-class
E30fixated
Post by E30fixated » Sat Jun 28, 2014 7:24 pm
Our local stealership says "no applicable recall" regarding my frau Janet's 2003 2.5 litre. They want $120 to read codes, credited on repair charges which could be substantial, they say. The airbag indicator lighted-up when a passenger briefly exited the vehicle, engine still running. No surprise, there are plenty of emulators to address the problem of a suspected seat mat sensor. I measure the resistance as ~1050 ohms, no load; under my 200 lb butt, the resistance goes up to 1100-1300 ohms inconsistently. An internet videoclip talks about 200 ohms in series with a 1N4001 diode for a home-made emulator; but otherwise I don't have a benchmark on this -- no Z4-owning friend to call upon.... unless someone on this forum has info to share. Many thanks in advance.... glenn in South Carolina.
