Roof motor scream
Roof motor scream
Hey guys,
Just a quick one, just wondering if it's normal for the roof motor to make a loud kind of scream noise when it's latching the roof closed?
I have a 3.0si which had the motor changed a couple of years ago by the owner before the last. The last owner said it has always made that noise whilst he had the car for a year and a half.
Its quite quick, takes less than the supposed healthy 10 seconds to open or close, just that when latching it really screams.
Thanks.
Thanks.
2006 3.0si
- Smartbear
Roof motor scream
Hi, sounds normal to me-at least that's the sound mine makes as wellknoxville wrote:Hey guys,
Thanks.
e85 3.0si sold
Roof motor scream
Thanks for the reply Smartbear,
I guess that's a relief then. It's such a loud (can only be described as screaming) noise.
Just need some nice summer sun now!
2006 3.0si
- Smartbear
Roof motor scream
You tend to get used to it after a while, I think the motor noise increases as the electric motor inside the front part of the hood completes the locking action.
e85 3.0si sold
- enzed4
Roof motor scream
My roof motor started doing this after I replaced it with a new one (the old waterlogged one didn't make it). It's really annoying me, so I've resurrected the old motor and first chance I get I'm going to swap them over, and relocate the motor to the boot.
Everyone seems to accept it as 'normal' but if I was buying the car brand new I would run a mile if the roof made as much noise latching as it does now.
I know it's normal for the roof motor to make an increased noise when it's latching, but I think I know exactly what the OP means by a 'screaming' motor, and it's not good.
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
Roof motor scream
At least you know it's still alive if it screams
Any chance you can get a video of it, just to see if it's like mine ?
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- benv6
Roof motor scream
I had that noise on a new motor. I topped it up with some hydraulic oil and the noise was completely gone. It became a lot quieter even though the motor was in the boot.
Roof motor scream
When my motor was moved into the boot by Dave he found the fluid was slightly low and topped it up.
That horrendous scream has now gone thank goodness.
[*]Sold,Silver grey 2007 2.5si Sport convertible.previous 03 2.7boxter,2.0 MX5,Golf R,2.9Boxster,golf gti,Now Z4 e23i and M135i
- enzed4
Roof motor scream
Thanks - this could be just what I need as I haven't checked the levels, just assumed it would be at the right level out of the box. I just bought some BMW hydraulic fluid for the old motor with the intention or reusing the old motor, but if a top up of the new motor fixes it I'll be well pleased. Still need to get the roof off to top it up though (sigh....). I can't pull the motor through to the boot as the sound insulation box is RTV'd shut (nice and watertight).benv6 wrote:I had that noise on a new motor. I topped it up with some hydraulic oil and the noise was completely gone. It became a lot quieter even though the motor was in the boot.
I will report back if a top up fixes this.
Cheers benv6
Gone: 2010 35i DCT
Roof motor scream
You need to top up the fluid. Mine is very very quiet. It's been relocated into the boot and yes you cam hear it but barely.
- enzed4
Roof motor scream
Removed roof, relocated motor, topped up fluid. Not much difference (slightly better, but that could be wishful thinking).
I have the old motor, but will leave the current one in to see if it improves. Not the end of the world (at least it works).
Gone: 2010 35i DCT
Roof motor scream
You need to use it a few times iirc to let it cycle through.enzed4 wrote:Removed roof, relocated motor, topped up fluid. Not much difference (slightly better, but that could be wishful thinking).
So use it every time you get in to the car even if it's a quick down and back up again. If it's not better after 10 cycles then it's the motor.
