*headslap* that was the reason!rjsimmons wrote:Might be because that lovely lady friend of yours looks better in a convertible than a Fiat...Chris_D wrote:Come to think of it- why the sh!t did i buy the zed??
Uh oh. Bennys' first tantrum! WAYHAAAY We're back in business! :) EDIT: 2000 mile update.
- Chris_D
Uh oh. Bettys' first tantrum! inc updates...
- Chris_D
Cold climate ccv kit finally arrived.
On checking the assembly i can already tell that the connection at the valve for the return hose is going to be an absolute b@stard as the valve insulation inhibits the connection.
Limbers up both physically and mentally.....here goes!
- image.jpeg (113.37 KiB) Viewed 1055 times
Having changed my CCV I can testify it was a ballache! The connectors will be brittle on the old one so expect them to break.
Do you have to take the manifold off on the M54? With 30% off at ECP it might be worth changing your starter while it's off to save potential faff in future.
- Marlon
Gone: 3.0si 2008 E85
911 997 Carrera S
- Chris_D
hahahaMarlon wrote:
- Chris_D
It actually benefitted from a new starter and alternator before i bought it. history included receipts which was reassuring!Scooba_Steve wrote:Having changed my CCV I can testify it was a ballache! The connectors will be brittle on the old one so expect them to break.
So I'm leaving that alone.
Hoping not to have to take off intake manifold but i suspect it might have to come to that due to the cumbersome insulation on this cold climate kit....
airbox, hoses, TB and ICV removed. Havin a cuppa before 'the big push' lol
- Chris_D
By crikey! 3 hours later and i'm still no closer to extracting the crappy old CCV kit, let alone installing the new one.
Seeing the much smaller non-cold climate version in situ is putting the fear of god in me that i'm not going to be able to squeeze the much bulkier cold-climate one in.
Hampered by those dreaded torx bolts holding the CCV valve itself in place atm. Pondering throwing in the towel before sh!t happens.....
Mustn't grumble. Keep calm and plod on.
Going to take my JBL Flip3 bluetooth speaker out after this cuppa and crank up some Joy Division to help things along....
- Chris_D
tell u what pop-pickers; these were a solid investment for keeping my hands clean!
i always thought that being so cak-handed as i can be sometimes that they would just rip to shreds but theyre holding up pretty well. only on my 3rd pair so far today....
- Chris_D
Farky Nell!
6.30pm, decided to call it a day.
Original valve still in place and connected to return hose and hose to air distributor. Rest of the connections freed up and hoses removed.
Tempted to hack away and cut at it to get everything out but I want to retain the valve just in case i can't get the new (bigger) one in and have to resort to re-using it.
No sign of condensate mayonnaise and hoses actually not that brittle. I would have suspected a CCV replacement had been carried out at some stage if it weren't for the fact that 2003 is stamped onto one of the hoses.
Will resume again tomorrow...
Jayzus ScoobaSteve, that S-bend hose is gonna be a real PITA to get installed, I can see it now! I'm already sore from all the contorting I did today!
Looks even worse than mine! Lots of small connectors was what I found slow going, a days work spread over two due to getting a new starter.
Good luck!
Good luck!
- Chris_D
Init tho- fiddly as f*ck! Did my head in today!Scooba_Steve wrote:Looks even worse than mine! Lots of small connectors was what I found slow going, a days work spread over two due to getting a new starter.
Good luck!
Well-earned chillax time tonight watchin narco's with cat and beers...
- sharpyboy
Don't despair, keep up the the good work we are all in this with you it's gonna be worth it in the end
2006 Z4 2.5i gap-tech rch+ roof mod + zhp + roof motor now in boot + DLV Exhaust mod
- Marlon
Yeah, well said sharpyboy.sharpyboy wrote:Don't despair, keep up the the good work we are all in this with you it's gonna be worth it in the end
So joking aside Chris, hoping you can turn this job around and get it sorted.
911 997 Carrera S
- Chris_D
Hahha thx sharpy! Encouraging words. Cat said the same when he wandered in. Then demanded i feed him.sharpyboy wrote:Don't despair, keep up the the good work we are all in this with you it's gonna be worth it in the end
- Chris_D
It'll be reet. MachineMonkey Mat said it best when he called it 'character-building' lolMarlon wrote:Yeah, well said sharpyboy.sharpyboy wrote:Don't despair, keep up the the good work we are all in this with you it's gonna be worth it in the end
