Non run flats
- DashBedrock
Non run flats
I've just replaced my Bridgestone RF's for Michelin pilot sport 4's and was initially very happy with the improvement in handling.
But I've just had a run on the motorway at speed and the front end feels very twitchy.
Do I need to have the wheel alignment adjusted? Or can anyone advise on possible cause of this.
It tramlined on the RF's but this is totally different and is just as unpleasant if not more so.
Up to speeds of say 50 there's no issue, but at 70, Oh dear!!!
- hopz121
Non run flats
Could be the alignment, could be Rear Trailing Arm Bushes, Front Lollipop bushes
Have you checked tyre pressures?
Checked wheels are torqued up correctly?
Tyres fitted in correct directions?
Front and back wheels not fixed to incorrect Axel?
When was the last time someone serviced/ took a look at the car.
Ash
Ash
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
- DashBedrock
Non run flats
Hi Ash,
Serviced approx 800 miles ago, Mot'd 2 weeks ago .Pressures all fine and wheels on correct axles etc. Would the rear trailing arm bushes cause a knocking? I've been reading the forum and put this down to diff clunk mentioned on several posts. The "at speed twitchyness" has literally started today. The non run flats were fitted yesterday afternoon.
Andy
Andy
- hopz121
Non run flats
Who did the service a BMW dealer, Specialist?
I would say you either have a bush or allignent issue if you have checked the above and all is well.
The bushes mentioned are prone to go on the z4 so that would be my first port of call.
- DashBedrock
Non run flats
Thanks for the reply Ash.
I've just looked through the mountain of receipts that came with the car and they include the following all done within the last 10 months.
Front lower wishbone arms
M3 anti roll bar
Anti roll bar bushes
Front suspension top mounts
Bilstein dampers
Eibach springs
Drop links.
I'm afraid I've only a limited mechanical knowledge
I've only had the car a week but the previous owner seems to have spared no expense when it came to maintenance.
It's puzzling me that the problem has only arisen after having the RF's replaced
Andy
M3 anti roll bar
Bilstein dampers
Eibach springs
Drop links.
Andy
Non run flats
Hmmm, know how you feel mate cos I'm having pretty much the same issues as you. I changed from run flats to non run flats on larger alloys and nowt but problems since!
- DashBedrock
Non run flats
I've just taken it out for a spin on the motorway and I have to say it's totally dangerous above 65. I feel safer driving my Transit.
Booking it in tomorrow to check track rod ends, bushes, control arms, drop links and anything else we can think of.
Been reading a few forums and it seems likely to be one or all of the above.
Non run flats
Very brave, spending hundreds on new tyres without getting the alignment checked first?
I would invest another £80 or so and get a 4 wheel alignement check done as soon as possible if you are confident that all the other work has actually been done.
2008 Z4 2.0i SE E85, Space Grey, 18" 241 staggered rims, 255/35/18, 225/40/18, 2 tone anthracite/silverstone leather Msport heated seats, M sport MFC Steering wheel, Bluetooth, Comfort pack, Tracker, Automatic climate control, Gaptech, Blah, blah.
- DashBedrock
Non run flats
Thanks for the input Geezah,
Would wheel alignment cause the front end to turn to jelly at high speed?
And should alignment always be checked after putting on new tyres?
Non run flats
How did the car drive/feel with the run flats on before you changed?
- DashBedrock
Non run flats
Without a doubt it tram lined but there was none of this scary stuff at high speed.
- mattyp
Non run flats
Defo get a wheel full 4 wheel alignment carried out by a specialist who understands and knows Z4's.
They are very sensitive to even minor out of alignment.
Mine had exactly the same issues at 60-70 ish until the car was set up and adjusted correctly.
E86 2007 Monaco Blue Metallic 3.0 Si SE with Beige Heated Leather
- DashBedrock
Non run flats
Thanks Matty.
I've been researching it all day and I think that's the best option as I have receipts for all the suspension and steering components recently replaced.
And thank you to everyone else for offering advise.
It's much appreciated
Andy
Andy
Non run flats
I don't know what could be causing this but it would be prudent to start off with the easy fixes first. Also you want to get the best life out of your expensive tyres so I would always check alignmrnt as a matter of course.DashBedrock wrote:Thanks for the input Geezah,
Non run flats
Newbie question. I have had my 85 3.0 for only a couple of weeks. The manual quoted tyre pressures seem very high, (iirc 33& 36psi) I'm assuming this is for run flats. My car has 'normal' tyres, which I'm pleased about, should pressures be the same?
