Shaking steering when braking
- Fanatic
My 04' Z has 83.000km
I have new rotors and brake pads (3000km) and overhauled calipers because I upgraded everything to 3,0si specs front and back. I bedded the brakes according to instructions.
When I am driving at high speeds >130-140km/hour and slow down by braking I can feel a tremble in the steering wheel. I cannot feel it when braking hard to a stand still or at slower speeds when braking for example at a traffic light. Recent MOT did not show any braking inconsistency but of course their tests are at lower speeds.
Any ideas??
Any ideas??
04' Z4 2.5i Maldives Blue - 108 alloys - Hardtop - 3,0si brakes F/R, BMW sport stubby, K&N filter, chrome exhaust tips, ZHP shift knob, cruise control, sound generator, twin clear reverse light, led dome light and footwell lights.
- pvr
Generally, I would look at warped disks but as they are new perhaps less likely.
When were the wheels last balanced?
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- buzyg
Have you changed any tyres recently. Could be a wheel imbalance, at it's as particular speeds.
- Smartbear
Mine exhibited the same behaviour & it was worn lollipop bushes
e85 3.0si sold
- Fanatic
I cannot think how 325mm discs could get warped without any track day use. I have not even put much pressure on them since replaced.pvr wrote:Generally, I would look at warped disks but as they are new perhaps less likely.
Tires were balanced and alignment was done about three months ago.
- Fanatic
Smartbear wrote:Mine exhibited the same behaviour & it was worn lollipop bushes
This sounds worth checking. Did they visually look worn?
- Smartbear
Still looked ok but had developed some slop, I replaced with mehley hd replacement bushes which were not oil damped but have a good reputation for lasting wellFanatic wrote:Smartbear wrote:Mine exhibited the same behaviour & it was worn lollipop bushes
e85 3.0si sold
- Fanatic
Just remembered I had one of them changed a few months ago. :/ Maybe the other one needs replacing also.Smartbear wrote:Still looked ok but had developed some slop, I replaced with mehley hd replacement bushes which were not oil damped but have a good reputation for lasting wellFanatic wrote:Smartbear wrote:Mine exhibited the same behaviour & it was worn lollipop bushes
Or do they go in pairs? Not sure.
- mattyp
Same for me also. I would be looking at suspension bushes.Smartbear wrote:Mine exhibited the same behaviour & it was worn lollipop bushes
E86 2007 Monaco Blue Metallic 3.0 Si SE with Beige Heated Leather
Most likely the lollipops - proper name brake reaction bushings. You could consider poly for these.
Brake discs really don't warp, but I'm not going to get into that.
- Fanatic
Scooba_Steve wrote:Most likely the lollipops - proper name brake reaction bushings. You could consider poly for these.
Number 8??
These are a few months old on mine. Original BMW
http://bmwfans.info/parts-catalog/E85/E ... _wishbone/
I would also appreciate reading why rotors don't warp?
Yes, so if both of those are new you could have worn arms (at 6 and/or 7) which you can check by trying to rock the wheel.
Next could be what would normally be termed warped discs. They won't actually be warped but the usual cure when paying is to replace due to labour costs. You could have them skimmed if you remove them yourself but deposits can return if not enough is removed and/or if there is any runout.
- Fanatic
But my discs are new. Is it possible that new discs can have this problem?Scooba_Steve wrote:Yes, so if both of those are new you could have worn arms (at 6 and/or 7) which you can check by trying to rock the wheel.
If they were installed with runout yes, but given the age of the cars I'd expect bushings to be failing - check the front control arms or get someone to do it as the first step.
