Water Pump Leak
Water Pump Leak
There is a safety guard thing right infront of the water pump so you cant pull it out...would raising the engine by 20mm help the situation?
- Mr Tidy
Water Pump Leak
No it isn't - just be grateful you don't have a facelift with the N52 engine!
The pump is electric and an OEM one is about £500 (or £340ish from ECP) plus £100 for a new thermostat !
Always look on the bright side of life!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Water Pump Leak
Undo the inlet side engine mount and jack up the engine from below, it will give you enough clearance..benben wrote:There is a safety guard thing right infront of the water pump so you cant pull it out...would raising the engine by 20mm help the situation?
2004 E85 Z4 2.5i SE Sterling Grey.
Water Pump Leak
yes.benben wrote:There is a safety guard thing right infront of the water pump so you cant pull it out...would raising the engine by 20mm help the situation?
Water Pump Leak
Mate, that was a golden advice. the mechanic guy was talking about removing the crash bar...600 quote....you guys are bloody legends. may you have good karma.
Water Pump Leak
When putting coolant in I think you have to either raise her or park uphill with heater on and bleed valve on expansion tank opened
http://www.pelicanparts.com/techarticle ... System.htm for the 3.0 not sure if the 2.5 is the same
Water Pump Leak
Thanks for all the advice gents,
Ended up doing it in the garage with a mate and changed the water pump, lower radiator hose, thermostat and both alternator and compressor belts.
On a different note the paint of the car is coming off at places due to being parked under the sun all these years. Any advice? (low budget advice haha)
