idej_jedi wrote:jamie_z4 wrote:You won't fix it with spacers mate it will make the problem even worse It will make the wheels more prominent which will rub the Arches more. Only resolution is wheels with a higher offset or raising suspension
Gutting! The article that I just read said that if the offset was too high it could be fixed with spacers.
Simply put Dan if your offset was 50 you could make it lower by adding a spacer so for example adding 15mm spacer would make your et or offset 35
Now if your offset is already 35 & you added a 5mm spacer it would make it 30 , , & the basic rule is the lower the number the further from the hub sits the wheel face so therefore a higher offset number can be made lower but a lower cannot be made higher ( or at least not without serious machining facilities
